Battery
1 Answer 0 Score |
Fan not working. linux. where to find replacement? |
2 Answers 1 Score |
Can I repair my adapter cable? |
1 Answer 1 Score |
I want to change the CPU in the pixel2013 |
2 Answers 0 Score |
touch screen not working |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Resources
Install Status
Microsoft Windows
Partial Success
Battery indicator not working
Debian Linux
Fully working
Remap volume & brightness keys
macOS
Partial Success
Touchscreen & battery indicator not working
Notable Features
Display
The screen's 4.3-million pixels work together to deliver crisp text, vivid colors, and extra wide viewing angles. The 12.85" screen had the highest pixel density of any laptop in it's time, and used a 3:2 photographic format designed for the web.
Interactions
A 0.55 mm layer of touch-enabled glass fused directly to the screen provides smooth touch interactions while preserving picture clarity.
Appeal
The Pixel boots-up in seconds, requires almost no setup or maintenance, and comes with virus protection built-in. It stays up to date with updates every few weeks.
Backlit keyboard
The backlights in the screen and keyboard respond to both the room's ambient lighting and how Pixel is being used. When watching a full-screen video, the keyboard automatically dims to an appropriate level.
Glass touchpad
The Pixel's touchpad is made from etched glass, analyzed and honed using a laser microscope for smoothness and accuracy during use.
Design
Detailed Technical Specifications
Motherboard
Manufacturer: GCE
Display
- 12.85-inch high resolution IPS
- Max Resolution 2560 x 1700
- Pixel Density 239 PPI
- 178° extra-wide viewing angle
- 400 nit brightness
- 3:2 aspect ratio
- Atmel mXT224SL maXTouch touchscreen controller
CPU
- Intel Core i5 Ivy Bridge with Panther Point PCH
- Processor Number i5-3427U
- 22 nm lithography
- Intel 3rd Gen Processor
- 1.8GHz dual-core
Graphics
- Intel Graphics HD 4000
Chipset
- Mobile Intel HM75 Express Chipset
- Intel BD82HM75 PCH
Memory
- 4GB Elpida DDR3 RAM
- Soldered on-board
Storage
- 32GB or 64GB SanDisk iSSD
- Soldered on-board
Battery
- Integrated 59.2 Wh
- 8000mAh Li-ion
- 7.4v
*Approximately 5 hours run-time
Connectivity
- Dual-Band WiFi (802.11a/b/g/n)
- Qualcomm Atheros AR5BMD22 802.11 integrated
- Bluetooth® 3.0 compatible
- Soldered on-board
External ports
- Internal USB 2.0 SD/multi card reader
- Mini-DisplayPort
- Combination headphone/microphone jack
- Two USB 2.0 ports
Audio
- Creative CA0132 Audio CODEC (CA0132-4AN HF)
Other features
- Full color power state indicator
- Integrated 720p HD camera
- Backlit Chrome keyboard
- Fully clickable etched glass trackpad
- Integrated stereo speakers
- Two built-in microphones for noise cancellation
Dimensions
- 297.7 × 224.6 × 16.2 mm (11.7 x 8.8 x 0.6 in)
Weight
- 1.52 kilograms (3.4 lb)
Case Material
- Anodized aluminum
