Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Dewalt DCD771C2 is a compact drill first made available in September of 2013. The Dewalt DCD771C2 is mostly used by homeowners and do-it-yourselfers. This drill’s lightweight design (6 pounds with battery) and length (9 inches) allows it to fit in tight areas and the high performance motor delivers 300 unit watts out (UWO) of power ability. It also has a high speed transmission which delivers two speeds (0-450 and 1500 rpm) for a variety of fastening and drilling applications.
Identification
This model can be identified by the sticker on the motor of the drill and is similar to the Dewalt DCD780C2 and the Dewalt DCD790D2.
Additional Information
Chuck and Clamshell Repair
Installing a Drill Bit or Accessory into Sleeve Chunk
Replacing the Switch
Emily Passey
354 Reputation
2 Guides authored
Cal Poly, Team 25-5, Maness Spring 2016 Member of Cal Poly, Team 25-5, Maness Spring 2016
CPSU-MANESS-S16S25G5
4 Members
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 98
All Time: 7,397
