The Dewalt DCD771C2 is a compact, lightweight, high performance drill released in September 2013 whose usage is ideal for projects around the house.
3 Questions View all
DeWalt lithium ion 18v issues
Hoping someone can help me out here I have 4 x 18v li ion batteries 2 of which are 5 months old & 2 which are 8 months old. When at work the other day one of the batteries ran out so I put it on charge to discover my other 3 were also flat, after charging all 4 batteries until the charge complete light came ON I went to use them to find that they all went flat after about 5 seconds of pressing the trigger on the drill so I then tried these batteries in other cordless tools such as my impact driver with no luck.
 I tested each battery with a multimeter and each battery had between 10-11 volts.
 I find it hard to believe all 4 batteries would die on the same day so I stuck my multimeter in the charger and although the 'charging' light would not flash the charger was out putting pulses of between .5 - 3.5v DC, is this normal?
 Does anyone know a method of pinpointing the problem? Eg battery cell test or charger test?
Score 2
Add a comment
1 Answer
Chosen Solution
I had the same problem! What I was doing wrong was I didn’t push the battery hard and far enough on the charger. When battery is inserted properly you will feel it click into place then the battery will truly charge.
Score 7
4 Comments:
Guy - Thank you from Florida. I read your answer and it works!
by
Yes worked thanks, needs a fair bit of muscle to force the battery onto charger. I am always scared I might break something using that much force!!
by
Sometimes you feel so stupid ? thanks for the answer
by
Thank you so much! I knew it had to be something i was doing wrong! Why isn't this made clear in the instructions?!!!
by
Add a comment
Add your answer
Drillbatterycomau will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 42
All Time: 4,987
