Capacitor
30 Diagrams
1 Answer 1 Score |
Machine will not power up |
No Answers 0 Score |
Is there a description of how to replace the intake nozzle? |
Machine pulsing when running |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
1.520-990.0
Background
The Kärcher Pressure Washer PRO HD 400 ED is a pressure washer from Kärcher that was released in 2018. This device is a cold water pressure washer designed for commercial use. It is also optimized to be lightweight and portable. This pressure washer can be used either vertically or horizontally, providing added convenience. Additionally, the Kärcher Pressure Washer PRO HD 400 ED has numerous built-in features for ease of use. For instance, the pressure washer has a carrying handle on the device and a retractable push bar handle. To prevent debris from getting into the water supply, the pressure washer has a removable, easy-to-clean filter. This pressure washer is also versatile. It is compatible with a range of accessories for various intended purposes.
Identification
The Kärcher Pressure Washer PRO HD 400 ED has a rectangular shaped base with two wheels and a carrying handle on the side. Additionally, there is a vertically extending push bar handle and, of course, the spray nozzle itself. The device is mostly gray in color.
Specifications
- Operating pressure: 1300 PSI
- Flow rate: 1.7
- Shipping Weight: 45 pounds
- Dimensions: 14 x 13 x 36 inches
- Power supply: 120 Volts, 60 Hz, 14 amps
- Model Number: 1.520-990.0
