Cap
1 Answer 0 Score |
Right Earcup Sound Failed |
No Answers 0 Score |
How to install replacement jack |
What kind of wire is used on the ear phone to the head band? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Kingston HyperX CloudX Gaming Headset for Xbox/Windows has been tested and approved by Microsoft. It delivers signature HyperX comfort, durability, and amazing sound for serious Xbox gamers. The HyperX CloudX has convenient in-line audio controls that sidestep system menus and puts control right at your fingertips. The sturdy aluminum frame is designed for long-lasting reliability and to withstand the harsh rigors of daily gaming life. The 100% memory foam ear cushions and leatherette-padded headband provide award-winning comfort for those long weekends and late gaming nights. 53mm drivers and enhanced bass reproduction pump out crystal clear highs, mids, and lows, and the closed cup design mutes the outside world to immerse you in your game completely. The noise-canceling microphone can be positioned just how you like it. It also eliminates background noise, so you’ll come across loud and clear. CloudX is also compatible with mobile devices. So when you’re ready to listen to music, unplug the microphone and stow it for later.
Source: HyperX CloudX
Identification
The Kingston HyperX CloudX Gaming Headset for Xbox One/Windows (Parts Number: HX-HSCX-SR) box will have a section on the front to distinguish what devices the headset is compatible with. In addition, the device box will be labeled "Xbox One & Windows" on the top edge and labeled "HyperX CloudX Pro Gaming Headset" on the top left corner of the front face.
Specifications
Headphone
- Driver: Dynamic, 53mm with neodymium magnets
- Type: Circumaural, Closed back
- Frequency Response: 15Hz - 25,000Hz
- Impedance: 60 Ω
- Sound pressure level: 98dBSPL/mW at 1kHz
- T.H.D.: <2%
- Weight: 309g
- Weight w/ mic: 322g
- Cable length and type: 1.3m (Headset) + 2m (PC extension cable)
- Connection: Headset - 3.5mm plug (4 pole) + PC extension cable and mic plugs
Microphone
- Element: Electret condenser microphone
- Polar pattern: Uni-directional, Noise-cancelling
- Frequency Response: 50Hz-18,000Hz
- Sensitivity: -39dBV (0dB = 1V/Pa, 1kHz)
Physical Specifications
- Weight: 0.71lb
- Cable Length (imperial) and type: Headset cable
Warranty
- 2 years
What's included in the box
- Gaming Headset, Detachable Mic, Quick Start Guide
Additional Information
Official HyperX CloudX Support Page
Official HyperX CloudX Specs/Benefits Page
