Battery
1 Answer 0 Score |
Part of the screen touch is not working. |
1 Answer 0 Score |
Bright horizontal lines on right side of the lcd after water damage? |
1 Answer 1 Score |
My fingerprint on my lg v40 not working |
1 Answer 0 Score |
water resistance and cracked back covers |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
V450PM (Sprint), V450VMB (Verizon), V500EM (Global), V500N (South Korea), V500XM (US Unlocked)
Troubleshooting
If you are experiencing difficulties with your LG V50 ThinQ, see the troubleshooting page to diagnose and resolve common problems.
Background
The LG V50 ThinQ (also called the LG V50 ThinkQ 5G) Android smartphone was produced by LG Electronics as released as part of the LG V smartphone series. It was released in April 2019 as the successor to the LG V40 Think Q. The V50 was available with a black body.
Externally, the V50 is very similar to the V40 model, with a 6.4-inch display and a scratch-resistant glass back and front and an aluminum frame. The V40 and V50 both feature dust-resistance and water-resistance in up to 1.5 meters of freshwater for up to 30 minutes. Both models are also MIL-STD-810G compliant, meaning that it complies with standard military environmental worthiness and overall durability.
The V50 includes a 4000 mAh non-removable battery, which is considerably larger than the V40’s 3300 mAh battery. (A non-removable battery is one whose adhesive is permanent, making repair and replacement difficult). The V50 also features 18-Watt fast-charging capabilities and 10-Watt wireless charging. It also has Qnovo’s intelligent battery management software built in to extend the lifespan of the battery. The V50 uses a Snapdragon 855 processor and supports 5G, which is the fifth generation technology for cellular networks. The phone is available with 6 GB of RAM and 128 GB of internal storage. This model also supports MicroSD card expansion for storage up to 1-terabyte and can be used with either single-SIM or dual-SIM setups.
Identification
The V50 ThinQ includes a flush rear camera and a 5G logo that lights up in specific colors depending on the carrier. The phone also includes the name V50 ThinQ in the center of the back, below the finger-print sensor. The LG logo is included at the bottom of the phone’s backing, which features the letters “L” and “G” in the form of a human face inside a circle.
Technical Specifications
Models: LM-V500, LM-V500N, LM-V500EM, LM-V500XM, LM-V450PM, LM-V450
Release date: April 2019
Body:
- Dimensions and Weight: 159.2 x 76.1 x 8.3 mm (6.27 x 3.00 x 0.33 in), 183 g (6.46 oz)
- Build: Glass front (Gorilla Glass 5), glass back (Gorilla Glass 6), aluminum frame
- SIM: Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
- IP68 dust/water resistant (up to 1.5m for 30 mins)
- MIL-STD-810G compliant
Display:
- Type: P-OLED capacitive touchscreen, 16M colors
- Size: 6.4 inches, 100.2 cm2 (~82.7% screen-to-body ratio)
- Resolution: 1440 x 3120 pixels, 19.5:9 ratio (~538 ppi density)
- Protection: Corning Gorilla Glass 5
- Always-on display
- HDR10
- Dolby Vision
Platform:
- OS: Android 9.0 (Pie), upgradable to Android 10
- Chipset: Qualcomm SM8150 Snapdragon 855 (7 nm)
- CPU: Octa-core (1x2.84 GHz Kryo 485 & 3x2.42 GHz Kryo 485 & 4x1.78 GHz Kryo 485)
- GPU: Adreno 640
Memory:
- Card slot: microSDXC (dedicated slot)
- Internal: 128GB 6GB RAM
- UFS 2.1
Main Camera:
- Triple
- 12 MP, 27mm (wide), f/1.5, 1/2.55", 1.4µm, dual pixel PDAF, 3-axis OIS
- 12 MP, 52mm (telephoto), f/2.4, 1.0µm, 2x optical zoom, PDAF, OIS
- 16 MP, 16mm (ultrawide), f/1.9, 1/3.1", 1.0µm, no AF
- Features: LED flash, panorama, HDR
- Video: 4K@30/60fps, 1080p@30/60/240fps, 24-bit/192kHz stereo sound rec., HDR10 video, gyro-EIS
Selfie Camera:
- Dual:
- 8 MP, f/1.9, 26mm (standard), 1/4", 1.12µm
- 5 MP, 21mm (wide), f/2.2, 1/5”, 1.12µm
- Features: HDR
- Video: 1080p@60fps
Sound:
- Loudspeaker: Yes, with stereo speakers
- 3.5 mm jack: Yes
- 32-bit/192kHz audio
- 24-bit/48kHz audio recording
- Tuned with Meridian Audio
Communications:
- WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, DLNA, hotspot
- Bluetooth: 5.0, A2DP, LE, aptX HD
- GPS: Yes, with A-GPS, GLONASS, GALILEO
- NFC: Yes
- Radio: FM radio
- USB: 3.1, Type-C 1.0 reversible connector
Features:
- Sensors: Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass, barometer
Battery:
- Non-removable Li-Po 4000 mAh battery
- Charging:
- Fast charging 18W, 50% in 36 min (advertised)
- Quick Charge 3.0
- USB Power Delivery 2.0
- Qi fast wireless charging 10W
Miscellaneous:
- Colors: New Aurora Black
