Cord
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Since it was established in 2017, the Levoit brand has been committed to creating clean and sustainable products. The Levoit LV-H132 was designed in California and was released in 2017. The base model comes in white color with black details and black with white details. This model uses the HEPA (High Efficiency Particulate Air) filtration system.
The LV-H132 air purifier makes only 43.1 dBA on the lowest operating level. Its compact size and 3-stage filtration system makes it ideal for home use. Pre-filter will stop large particles, H132 traps small particles, and the Active Carbon Filter will absorb compounds and odors. The Levoit LV-H132 removes 99.97% of contaminants and traps small particles like pet dander, fine dust, and pollen from the air in a room to improve indoor air quality.
It is designed to thoroughly clean and purify the air in medium and large-sized rooms, providing complete coverage for areas up to 516 square feet (48 square meters) per hour. You can get filter replacements for the air purifier directly from the brand's website, eliminating the need to search for replacements elsewhere.
Identification
It is a round cylindrical object. It has dimensions of 7.9 x 7.9 x 12 in. Looking from the top you can see a fan with some buttons in its circumference. It has four buttons which are the power button, nightlight button, check filter indication button, and fan speed button. It has an LED blue night light system between the air fans. From the front you can see the company’s name “Levoit”. It has an air filter on the lower part of the body. The model number on the device is located behind the device, below the power cord.
Technical Specification
- Voltage: AC 120V, 60Hz
- Rated Power: 28W
- Effective Range: 129 ft^2 / 12m^2
- Dimensions: 7.9 x 7.9 x 12.6 in / 20 x 20 x 32 cm
- Weight: 6 lb / 2.7 kg
- Operating Conditions Temperature: 14^o - 104^oF / -10^o -40^oC
- Humidity: < 85% RH
- Noise Level: < or equal to 50dB
- CADR: 40 CFM
- Standby Power: < 0.8W
