Battery
4 Answers 5 Score |
MacBook Air M2 (MBA M2) high noise/ hinge clicks while fully open the |
5 Answers 6 Score |
Upgrade NAND SSD Storage? |
2 Answers 0 Score |
How to replace full keyboard on this model A2681? |
2 Answers 2 Score |
Anyone knows where the lid sensor is located for the M2 MacBook Air? |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A2681 EMC 4074 Mid 2022 Mac14,2 3.49 GHz M2 8-Core/10-Core GPU, A2681 EMC 4074 Mid 2022 Mac14,2 3.49 GHz M2 8-Core/8-Core GPU
News
Background and Identification
Identified by model numbers A2681, MLY43LL/A, or MLY33LL/A (printed on the back cover).
Apple first unveiled the new MacBook Air, fully redesigned for 2022, at WWDC on June 6, 2022. Starting at $1199 USD, it's available in Starlight, Silver, Space Gray, or Midnight. While still impressively thin and light, it's characterized by a more squared-off design, lacking the tapered wedge shape of its predecessors. It also has a prominent notch at the top of the display, similar to those seen on the 2021 MacBook Pro models.
Repairs for this model can be challenging; pentalobe screws guard the exterior, the battery is secured with both stretch-release adhesives and screws and requires removing the logic board for access, and both memory and storage are non-serviceable and non-upgradeable. On the plus side, the MagSafe, Thunderbolt, and headphone/3.5 mm audio ports are all highly modular.
Technical Specifications
Display:
- 13.6-inch (diagonal) Liquid Retina LED-backlit display with IPS technology
- 2560×1664 native resolution at 224 pixels per inch
- 500 nits brightness
- Wide color (P3)
- True Tone
Processor:
- Apple M2 8-core CPU with 4 performance cores and 4 efficiency cores
- 8-core GPU configurable to 10 cores
Memory:
- 8 GB unified memory (base model)
- Configurable to 16 GB or 24 GB
Storage:
- 256 GB (base model)
- Configurable to: 512GB, 1TB, or 2TB
Wireless Connectivity:
- 802.11ax Wi-Fi 6 wireless networking IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.0
Ports:
- MagSafe
- 2x Thunderbolt 3 / USB 4
- 3.5 mm headphone jack
Battery:
- 52.6 watt-hour lithium-polymer battery
Speakers
- 4 speaker system: 2 tweeters, 2 subwoofers
Dimensions:
- Height: 0.44 inch (1.13 cm)
- Width: 11.97 inches (30.41 cm)
- Depth: 8.46 inches (21.5 cm)
- Weight: 2.7 pounds (1.24 kg
