Face Plate
3 Answers 0 Score |
Why are all LEDs flashing? |
2 Answers 0 Score |
My device won't turn on! |
1 Answer 0 Score |
WiFi connection cuts me off |
1 Answer 1 Score |
Upgrading my Cable Modem to DOCSIS 3.0 SB6141 |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
In order to troubleshoot common problems with this device, please visit the Motorola SURFboard SB5101 Troubleshooting Page.
Background Information
The SB5101 model was released alongside the existing 5100 model and was intended to be its eventual replacement. The biggest change is a new standby button on the top of the device that resets the USB and ethernet connections without disconnected the modem from the network. This new feature is intended to give end-users more security by protecting their computer from unwanted external access.
This new model is also DOCSIS® 1.1 and 2.0 certified while still being compatible with DOCSIS® 1.0. This modem works with Windows®, Macintosh®, Unix® and Linux® computers. It can support up to 63 users at one time, and features a sleek upright design that saves desk space. It can also receive software updates over the network.
Information found in the product overview provided by the manufacturer.
Technical Specifications
Height: 6.2 inches
Width: 2.3 inches
Depth: 6 inches
Environmental efficiency: RoHS Compliant, FCC Approved
Configuration: 10/100 Base-T Ethernet Port and USB Port
Certifications: DOCSIS® 2.0 and 1.1 certified
Compatibility: Compatible with Windows® Vista®/ 2000/XP™ (older versions of Windows, although not specifically supported, will work with this cable modem); Macintosh® Power PC or later, OS 9 or higher; Unix®; or Linux®
Security: Delivers security with improved data encryption and commercial-grade firewall
Performance: Capable of downloading speeds up to 38 Mbps
Installation: Quick and easy self-installation
Information found on the product page created by the manufacturer and on the product specifications page created by Best Buy.
