Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Panasonic ES2207P handheld women's shaver with 3 blades and pop-up trimmer. Power switch on underside. Buttons on either side to remove foil head. Charger plugs in on end of shaver.
Common failure with battery charging.
Power specs:
  • 120V 60Hz input to charger
  • 1.3V output from charger
  • 1.2V motor
User serviceable parts:
  • Foil - WES9775P
  • Blade - WES9752P
  • Blade/foil set - WES9769P
  • AC Adapter - RE7-43
Identification
The model number can be found on the front of the shaver above the charging port.
Additional Information
Panasonic ES2207P (Panasonic store page)
Panasonic ES2207P Customer Reviews (Amazon)
Panasonic ES2207P Review (ShaverGuru)
Kevin Marvell
309 Reputation
2 Guides authored
IUPUI, Team S6-G5, Baechle Fall 2017 Member of IUPUI, Team S6-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G5
3 Members
4 Guides authored
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 18
All Time: 2,645
