Latch Button
1 Answer 0 Score |
My Philips air fryer, cannot close |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Philips HD9252 is an air fryer from the Philips 3000 series of products. The Philips HD9252 was released by Philips in May 2021 and can be used to air fry any food you have available. The air fryer is black in color and weighs 10 lbs. The air fryer pan’s volume is 1 gallon and serves 13 different cooking functions (fry, defrost, bake, etc.). The air fryer connects to Wi-Fi using the Philips app.
This Philips air fryer model is similar in design and function to many other air fryers available and bears a resemblance to other models Philips has produced. Research failed to show any known failure modes or recall campaigns for the product. This model received largely positive reviews due to its ease of use and multiple different functions. The most common problem reported was a constant beeping after pressing start.
Philips has made many other models of air fryers. This model is capable of cooking meals using up to 70% energy and 50% faster than traditional ovens. It comes with a built-in LED display and touch screen. It can also be partially disassembled for washing.
Identification
The Philips HD9252/91 air fryer has a sleek, compact body with a removable tray in the front and air filter in the back. The screen in the middle has all the buttons needed to use the device. The top of the front of the device has the brand name, “Philips.”
Technical Specifications
Dimensions:
- 360x264x295 mm (L×W×H)
- 13.1"D x 13.1"W x 13.8"H
Weight:
- 4.55 kg (10.0 lbs)
Cord length:
- 0.8 m
Power:
- 1400 W
Material of main body:
- Plastic
Pan:
- 4.1 L (135 Fl oz)
- 1.08 Gal
Product Features:
- Automatic shut-off
- Cool wall exterior
- Dishwasher safe
- On/off switch
- Ready signal
- Temperature control
- Power-on light
- Quick clean
- LED display
- Patented Rapid Air
- Time control
Additional Information
Philips HD9252/91 Air Fryer Official Page
