Battery
2 Answers 0 Score |
My power button got stuck |
4 Answers 2 Score |
Right cup not producing sound at all. |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are having issues with your Razer Barracuda X and need additional help, here is the troubleshooting page.
Background
The Razer Barracuda X is a standard gaming headset produced by Razer themselves in 2021. The Razer Barracuda X is used primarily in gaming environments. The Razer Barracuda X has built in wireless Bluetooth technology. This headset also comes with a detachable mic that has a frequency range from 100-10kHz.
This headset weighs 250 grams, making this headset on the lighter side of most headsets. The Razer Barracuda X also includes a mute button on the side of the headset. Like most technology today, the Razer Barracuda X uses the USB Type-C Wireless (2.4GHz), Bluetooth 5.2, 3.5mm Analog connection port.
This model of headset is standard in terms of most gaming headsets with a detachable mic. No recalls have been made via Razer about the Razer Barracuda X and minimal complaints have been found online for this headset. There are two versions of this headset, black and white and the color does not affect the quality of the headset, there is no difference between the two.
Identification
The Razer Barracuda X has sleek yet comfortable design. You can also find the mute button, power button, volume scroll wheel, detachable mic port, and charging port on the left side of the headset. To further identify the device, you can look for the Razer logo on both sides of the headset. To find the model number, look on the bottom of the box the device came in.
Specifications
FREQUENCY RESPONSE: 20 Hz – 20 kHz
IMPEDANCE: 32 Ω (1 kHz)
SENSITIVITY: 96dBSPL/mW@1KHz by HATS
DRIVER SIZE: DIAMETERS (MM)40 mm
DRIVER TYPE Razer™: TriForceEARCUPSOval FlowKnit Ear Cushions
INNER EARCUP DIAMETER: 60 mm x 40 mm
EARPADS MATERIAL: Ultra-soft FlowKnit memory foam
NOISE CANCELLING: Passive noise cancellation
CONNECTION TYPE: USB Type-C Wireless (2.4GHz), Bluetooth 5.2, 3.5mm AnalogCABLE
LENGTH: 1.5 m / 4.92 ft
APPROXIMATE WEIGHT: 250 g / 0.55 lbs
MICROPHONE STYLE: Detachable HyperClear Cardioid
PICK-UP PATTERN: Unidirectional
MICROPHONE FREQUENCY RESPONSE: 100 Hz - 10 kHz
MICROPHONE SENSITIVITY: (@1KHZ)-42 ± 3 dB
VIRTUAL SURROUND ENCODING: 7.1 Surround sound: Only available on Windows 10 64-bitVOLUME
CONTROL: Volume up and down
OTHER CONTROLS:
- Mic mute on / off toggle
- 2.4GHz Wireless and Bluetooth Toggle (SmartSwitch)
- Play/pause track, accept incoming call or end current call, skip track, previous track
BATTERY LIFE: Up to 50 hours
LIGHTING: None
COMPATIBILITY:
- PC (USB Type-C 2.4GHz, Bluetooth 5.2)
- PlayStation (USB Type-A to USB Type-C 2.4GHz)
- Mobile Devices (Supporting USB Type-C or Bluetooth 5.2)
- Android & iOS
