Ask a Question
There are no questions. Be the first to ask a question!
Troubleshooting
If for any reason you are experiencing a problem with the Ryobi CSB125 saw, refer to this troubleshooting page for guidance.
Background and Identification
The Ryobi CSB125 is a 13 Amp, 7.25 inch circular saw that was released in 2014. The saw has multiple features, including a front pommel handle to help make the saw comfortable to use, an on-board wrench storage for easy removal of the blade, and an adjustable depth of cut with scale to improve the accuracy of cuts.
A similar model is the Ryobi CSB135L. The major differences between the two models are that the Ryobi CSB135L uses 14 Amps and also has a laser for increased precision with cuts.
The Ryobi CSB125 has not faced any kind of large-scale recalls and generates favorable reviews. One important factor to take into consideration when using the saw is the blade that comes along with it. Most reviews of the saw strongly suggest to purchase a new blade and immediately replace the blade, as they noted that the blade that comes along with the saw is “junk”. Other than the junk saw blade, the reviews of the circular saw are good.
Listed below are some of the features that are associated with the Ryobi CSB125:
  • Depth Adjustment
  • Key-less Blade Change
  • Spindle Lock
Specifications
Depth: 9.5 in
Height: 9.5 in
Width: 12 in
Blade Diameter: 7.25 in
Max cut depth @ 45 deg: 1.875 in
Max cut depth @ 90 deg: 2.438 in
Amperage: 13
Bevel Capacity: 51.5
Max speed RPM: 5,000
Weight: 7 lbs
Blade Location: Right
(Source)
Additional Information
Ryobi Home Page
Home Depot Ryobi Product Information
Ryobi Replacement Parts Website
Amazon Product Page
Curtis Melo
1,093 Reputation
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,039
