Background
The Ryobi P202 is part of the Ryobi One+ 18 volt cordless tool system. It is sold in the Ryobi P817 kit with a charger, battery, and carrying case. It is compatible with both the original NiCad and newer Lithium Ion battery packs.
This model has neon green plastic with grey rubber coverings. It has a built in level gauge and a two speed switch on the top of the drill. A magnetic tray, and drill bit clip are found on the base of the drill. The drill has a pressure sensitive trigger and has a maximum RPM of 1600 as seen on the warning label.
Identification
With the trigger pointing right, the label on the side of the drill shows a warning label as well as the identification name of P202.
Technical Specifications
  • 18-Volt
  • Holds up to 1/2 inch drill bits
  • Spins up to 1600 RPM
  • 24 torque settings
  • Level gauge
  • Magnetic tray
  • Drill bit clip holder
Additional Information
Ryobi Manual
Ryobi One+ Overview
Blown Out Diagram
Wiring Diagram
Manuals Lib Manual
Parts List
Joseph Eckstein
1,596 Reputation
9 Guides authored
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Members
10 Guides authored
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 87
All Time: 16,226
