Display Assembly
1 Answer 0 Score |
Connection point for sub flex cable damaged on mobo |
3 Answers 4 Score |
Repair Guides for S20 FE? |
2 Answers 0 Score |
Can I replace a SM-G780F board with a SM-G781V board |
1 Answer 0 Score |
Why isn't my usb c port working? |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
SM-G780F, SM-G780F/DSM, SM-G780G
Technical Specifications:
- CPU: Qualcomm Snapdragon 865 Octa-core (1x2.84 GHz Kryo 585 & 3x2.42 GHz Kryo 585 & 4x1.8 GHz Kryo 585)
- Storage Options: 128GB 6GB RAM, 128GB 8GB RAM, 256GB 8GB RAM
- Display
- 6.5 inch Super AMOLED 120Hz
- 1080 x 2400 pixels, 20:9 ratio (~407 ppi density)
- Cameras
- Main Cameras: 12 MP, f/1.8, 26mm (wide), 1/1.76", 1.8µm, Dual Pixel PDAF, OIS
8 MP, f/2.4, 76mm (telephoto), 1/4.5", 1.0µm, PDAF, OIS, 3x optical zoom
12 MP, f/2.2, 13mm, 123˚ (ultrawide), 1/3.0", 1.12µm - Front-facing Camera: 32 MP, f/2.2, 26mm (wide), 1/2.74", 0.8µm
- Ports and Connectivity
- Wi-Fi 802.11 a/b/g/n/ac/ax (2.4/5GHz) MIMO
- Bluetooth v5.0
- ANT+
- NFC
- GPS
- USB Type-C
- Battery: 4,500 mAh integrated li-ion battery
- Dimensions
- Size: 159.8 x 74.5 x 8.4 mm (6.29 x 2.93 x 0.33 in)
- Weight: 190 g (6.70 oz)
- Additional Features
- IP68 water/dust resistance rating (1.5 meters underwater up to 30 minutes)
