Antenna
3 Answers 3 Score |
My CD won’t play it just says Reading |
1 Answer 0 Score |
USB not working shuts down player |
1 Answer 0 Score |
FM Radio not working |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are experiencing problems with your Sony ZS-RS60BT Bluetooth boombox, try referring to the troubleshooting page.
Background
The Sony ZS-RS60BT was manufactured by Sony on June 24, 2007.
The device is equipped with radio reception, Bluetooth compatibility, CD playback, and USB and auxiliary capabilities. The Sony Bluetooth boombox allows you to record music to and play music from a USB drive. The boombox has a power cord but is also capable of being battery operated using 6 C-grade batteries.
Identification
The Sony ZS-RS60BT can be identified as a Sony Bluetooth boombox. While its black coloring could cause it to be confused with other similar models, the ZS-RS60BT can be identified by the white Sony label and the model number. The model number can be found on the device above the LCD display screen.
Additional Information
Manufacturer's Page: Sony ZS-RS60BT
