Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
For additional help on the Toastmaster THMP2, check out the troubleshooting page.
Toastmaster TMHP2 Troubleshooting
Background
The Toastmaster TMHP2 Hot Pot is an electronic kitchen appliance designed to heat up liquid foods. The device was released in May 2004.
This device’s model number is now obsolete. It is not to be confused with the Toastmaster THMP2 gas hot plate. Which was released in 2013 and is a much higher power gas cooking device.
The Toastmaster TMHP2 is a white plastic pot about 16cm in diameter. There is a plastic handle on the side and a white power cable underneath the handle. On the front of the pot there is a dial for temperature control and a toastmaster logo printed above it. On the bottom of the pot there is a vent for airflow from the heating element. The heating element on the inside of the pot is coated with a non stick coating. There are 3 small rubber feet which keep the pot elevated from the ground. The device must be filled with liquid before turning it on, otherwise it will be a fire hazard and risk burning your food.
Identification
The Toastmaster TMHP2 Hot Pot model number (TMHP2) is on the manufacturer label, which is affixed to the bottom cover of the pot.
Specifications
  • 32oz capacity
  • 1000 watts
  • 120V AC ~60hz input
  • 13.9cm width
  • 15.8cm diameter
Additional Information
Toastmaster TMHP2 Use and Care Manual
eBay Page
Amazon Reviews
Toastmaster is a part of the Star International Holdings group of brands. There is no longer official documentation for the Toastmaster TMHP2 hot pot from the Star International Holdings group available online as it is outdated.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 457
