Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Tools
Here is a list of some tools used to work on your Roomba. You may or may not need all of them, depending on the procedure.
Phillips #1 screwdriver
Troubleshooting
Diagnose common problems with your Roomba 4160 with our Roomba 4160 Troubleshooting Guide
Identification and Backgroud
The iRobot Roomba 4160 is part of the Roomba 4100 series line of autonomous vacuuming robots. The 4160 model has 3 main input buttons located on the top, as compared to the Roomba 4100 which has two main input buttons located on the top, and is teal in color. Released in 2006, the Roomba 4160 uses a dual brush system, along with a rotating edge brush to collect dirt from along the edges of walls and baseboards. It has the ability to dock and recharge itself when the battery runs low, and can be preset to clean on a set weekly schedule.
The Roomba 4160 also uses the Virtual Wall system, allowing you to block off areas you do not want the Roomba to clean. It features a remote control, so you can easily control the Roomba from anywhere in your house.
Additional Information
Roomba Assembly Guide
Roomba Disassembly Videos
Roomba 4100 Series Information
Philippe Napaa
222 Reputation
2 Guides authored
Cal Poly, Team 6-4, Forte Spring 2014 Member of Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 3,495
