2012-2015 Honda Civic Spark Plugs Replacement
  1. 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: step 1, image 1 of 3 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: step 1, image 2 of 3 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: step 1, image 3 of 3
    • Use a flathead screwdriver to remove the two screws holding the engine cover in place.
    • Remove the engine cover.
  2. 2012-2015 Honda Civic Spark Plugs Replacement: step 2, image 1 of 2 2012-2015 Honda Civic Spark Plugs Replacement: step 2, image 2 of 2
    • Locate the four spark plug connectors.
    • Insert a screwdriver into the space in the wire connector and lift the lid.
  3. 2012-2015 Honda Civic Spark Plugs Replacement: step 3, image 1 of 3 2012-2015 Honda Civic Spark Plugs Replacement: step 3, image 2 of 3 2012-2015 Honda Civic Spark Plugs Replacement: step 3, image 3 of 3
    • Locate the bolt securing the ignition coil.
    • Use a wrench with a 10 mm socket to remove the bolt securing the ignition coil.
    • Once the bolt is removed, pull out the ignition coil.
  4. 2012-2015 Honda Civic Spark Plugs Replacement: step 4, image 1 of 3 2012-2015 Honda Civic Spark Plugs Replacement: step 4, image 2 of 3 2012-2015 Honda Civic Spark Plugs Replacement: step 4, image 3 of 3
    • Locate the old spark plug.
    • Use a wrench with a spark plug socket (with a rubber grommet) to unscrew the spark plug.
    • Once the spark plug is unscrewed, pull out the wrench along with the spark plug.
  5. 2012-2015 Honda Civic Spark Plugs Replacement: step 5, image 1 of 2 2012-2015 Honda Civic Spark Plugs Replacement: step 5, image 2 of 2
    • Ensure that the new spark plug is dry.
    • Use a gap measuring tool to ensure that the spark plug gap is appropriate.
    • It is optional to lightly coat the threads with anti-seize to help remove them in the future.
    • Do not get anti-seize on the electrodes (the gap at the top of the threads).
  6. 2012-2015 Honda Civic Spark Plugs Replacement: step 6, image 1 of 2 2012-2015 Honda Civic Spark Plugs Replacement: step 6, image 2 of 2
    • Attach the new spark plug to the spark plug socket, and finger tighten the new spark plug.
    • Use the wrench to tighten the spark plug to 45 degrees.
    • Do not overtighten the spark plug.
    • Re-insert the ignition coil.
  7. 2012-2015 Honda Civic Spark Plugs Replacement: step 7, image 1 of 2 2012-2015 Honda Civic Spark Plugs Replacement: step 7, image 2 of 2
    • Use the wrench with the 10 mm socket to tighten the bolt that fastens the ignition coil.
    • Re-connect the wire connecter to the ignition coil.
Repeat steps for the remaining 3 spark plugs. Reattach the engine cover with the flathead screwdriver.
2 other people completed this guide.
Anthony
175 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 20
Past 7 Days: 80
Past 30 Days: 270
All Time: 2,821
