BlackMagic ATEM Television Studio Quiet Fan Upgrade
Video Overview
  1. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Unscrew the Outer Case: step 1, image 1 of 1
    • 2 Screws on each side
    • 6 Screws on top
  2. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Remove Fans: step 2, image 1 of 1
    • Remove Both Fans
    • 2 - Screws each
    • 1 - Pull cable each
  3. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Cut Off Connector from both the olds and new fans: step 3, image 1 of 1
    • Leave some length to solder with and to reach connector on main board.
  4. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Prep Fan Wires and Connector Wires: step 4, image 1 of 1
    • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
  5. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: step 5, image 1 of 3 BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: step 5, image 2 of 3 BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: step 5, image 3 of 3
    • For Both Fans
    • Solder the new fan to the old connector using the following pinout.
    • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
  6. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Re-assemble fans to device with fan label facing out: step 6, image 1 of 1
    • Re-assemble fans to device with fan label facing out.
  7. BlackMagic ATEM Television Studio Quiet Fan Upgrade, OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter: step 7, image 1 of 1
    • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
  8. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Re-Assemble Case: step 8, image 1 of 1
    • Re-Assemble Case
5 other people completed this guide.
Kevin Krautle
562 Reputation
2 Guides authored
5 Comments
I have an ATEM Production Studio 4K which had the same issue. This guide was helpful to know how to map the exhaust fan wiring. There are 2 12v heat sync fans that have the same color scheme. I just crimped the wires strait across, and everything worked. I’m now able to live edit without the distraction of a loud switch!
Thank you!!
longears - Reply
I just did the same on my atem m/e production 4k but the side fans (exhaust) are not on. I wonder if there’s a threshold at which they power on? Any recommendation? The heat sink fans work right away.
Beto Gudiño -
Can I have a schematic diagram for this product ?
Jay Makwana - Reply
Awesome video, thanks! Do you have a similar iFixit kit and video for the ATEM Mini Pro?
Al Rodriguez - Reply
Great mod! Did this on my TV Studio HD, nearly non hearable now :)
Andi M - Reply
Past 24 Hours: 2
Past 7 Days: 68
Past 30 Days: 126
All Time: 7,951
