Blackberry Bold 9000 Trackball Replacement
  1. Blackberry Bold 9000 Trackball Replacement, Battery: step 1, image 1 of 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: step 2, image 1 of 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: step 3, image 1 of 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: step 4, image 1 of 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: step 5, image 1 of 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: step 7, image 1 of 1
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: step 8, image 1 of 1
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: step 9, image 1 of 1
    • Lift the trackball out of its socket.
5 other people completed this guide.
Kelly
566 Reputation
6 Guides authored
Cal Poly, Team 8-17, Maness Winter 2012 Member of Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 23
All Time: 11,313
