Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement
  1. Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
    Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Safety precautions: step 1, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Safety precautions: step 1, image 2 of 2
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 2, image 1 of 1
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 3, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 3, image 2 of 2
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 4, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 4, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Unbolt the cutter blade: step 5, image 1 of 1
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
    • You may need to use a 1/2 inch wrench in combination with the socket wrench to hold the nuts in place.
  6. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 6, image 1 of 1
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
  7. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Remove the cutter blade: step 7, image 1 of 3 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Remove the cutter blade: step 7, image 2 of 3 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Remove the cutter blade: step 7, image 3 of 3
    • Slide the cutter blade out from under the machine to remove it.
    • Do not handle the blade from the cutting edge.
  8. Careful: steps 8-10 are sourced from a guide that's marked as in-progress.
    Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Remove the chain guard: step 8, image 1 of 1
    • Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
  9. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 9, image 1 of 1
    • Carefully tilt the sod cutter on its side.
    • Use a 9/16 inch socket to remove the nut securing the chain guard.
  10. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 10, image 1 of 3 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 10, image 2 of 3 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 10, image 3 of 3
    • Remove the chain guard.
  11. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement, Remove the upper chain: step 11, image 1 of 1
    • Use a 1/2 inch socket to remove the two bolts securing the upper chain guard to the frame.
  12. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 12, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 12, image 2 of 2
  13. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 13, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 13, image 2 of 2
    • Use a pen to mark the location of the sprocket on the bracket.
    • During reassembly, line up the edge of the washer with the mark to get the sprocket as close to its original location as possible.
  14. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 14, image 1 of 3 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 14, image 2 of 3 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 14, image 3 of 3
    • Use a 3/4 inch socket to loosen the bolt securing the tensioner sprocket until it can freely slide up and down the bracket.
  15. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 15, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 15, image 2 of 2
    • Roll the machine to turn the chain until the master link is accessible.
    • Notice the open end of the master link retaining plate is facing down.
  16. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 16, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 16, image 2 of 2
    • Use pliers to remove the master link retaining plate.
    • Install the new chain with the open end of the master link facing the same direction.
    • Do not install the new chain with the open end of the master link facing up or it could come off during operation.
  17. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 17, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 17, image 2 of 2
    • Remove the master link.
    • The chain will fall.
  18. Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 18, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Upper Drive Chain Replacement: step 18, image 2 of 2
    • Remove the chain.
Sam Omiotek
83,715 Reputation
290 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 634
