Core Assembly Removal
  1. Core Assembly Removal, Opening Procedure: step 1, image 1 of 1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Core Assembly Removal: step 2, image 1 of 2 Core Assembly Removal: step 2, image 2 of 2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Core Assembly Removal: step 3, image 1 of 2 Core Assembly Removal: step 3, image 2 of 2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Core Assembly Removal: step 4, image 1 of 2 Core Assembly Removal: step 4, image 2 of 2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Core Assembly Removal: step 5, image 1 of 3 Core Assembly Removal: step 5, image 2 of 3 Core Assembly Removal: step 5, image 3 of 3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Core Assembly Removal, Core Assembly Removal: step 6, image 1 of 2 Core Assembly Removal, Core Assembly Removal: step 6, image 2 of 2
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Core Assembly Removal: step 7, image 1 of 2 Core Assembly Removal: step 7, image 2 of 2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
5 other people completed this guide.
Tobias Isakeit
118,058 Reputation
189 Guides authored
3 Comments
thanks, loved seeing this watch from the inside!
Crystal Blu - Reply
Great, but now I need to know how to get to the glass to replace it.
selwood.maria - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 2,953
