Disconnecting Microphone from Motherboard
  1. Disconnecting Microphone from Motherboard, Front and Back Cover: step 1, image 1 of 2 Disconnecting Microphone from Motherboard, Front and Back Cover: step 1, image 2 of 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Disconnecting Microphone from Motherboard: step 2, image 1 of 2 Disconnecting Microphone from Motherboard: step 2, image 2 of 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Disconnecting Microphone from Motherboard, Microphone Connection: step 3, image 1 of 2 Disconnecting Microphone from Motherboard, Microphone Connection: step 3, image 2 of 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
Timothy Forrest
19 Reputation
2 Guides authored
Cal Poly, Team 12-34, Amido Spring 2013 Member of Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Members
16 Guides authored
One Comment
This guide doesn’t show a motherboard and is a copy of this other guide (for a webcam):
Logitech Webcam Pro 9000 Microphone Replacement
Maximilian Cohan - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,671
