Durofix RV332 Battery LED Replacement
  1. Durofix RV332 Battery LED Replacement, Battery LED: step 1, image 1 of 1
    • Remove the six 13 mm case screws with a #0 Phillips screwdriver from the side of the power screwdriver.
  2. Durofix RV332 Battery LED Replacement: step 2, image 1 of 2 Durofix RV332 Battery LED Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, separate the case in two to expose the internals of the cordless screwdriver.
  3. Durofix RV332 Battery LED Replacement: step 3, image 1 of 3 Durofix RV332 Battery LED Replacement: step 3, image 2 of 3 Durofix RV332 Battery LED Replacement: step 3, image 3 of 3
    • Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing.
    • Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board.
    • Remove the LED from the circuit board while the solder is still melted.
  4. Durofix RV332 Battery LED Replacement: step 4, image 1 of 2 Durofix RV332 Battery LED Replacement: step 4, image 2 of 2
    • Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place.
    • Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
Tyler Vincent
479 Reputation
4 Guides authored
One Comment
Hello, I would ask the author about the type and model number of the electronic element marked as Q1 on the PCB (transistor or thyristor) on the third picture in Step 3 of this article, because mine is burnt out, and on this picture can't be read anything.
Greetings,
Plam
Пламен Петракиев - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,127
