Galaxy Note 2 - N7100 Complete Disassembly & Assembly
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Instructions
To reassemble your Galaxy Note, follow the complete video
51 other people completed this guide.
LE55ONS
10,969 Reputation
6 Guides authored
12 Guide Comments
Brilliant. Thank you.
churchst71 - Reply
Very complete guide. If you need to replace your screen - MAKE SURE you order the part with the plastic chassis and home key attached to the glass. You will be much happier, trust me.
Justin Long - Reply
Also-
In the linked video which describes separating the digitizer and glass from the plastic chassis I believe there is a missing step in the reassembly which is critical.
There is a metal grommet on the glass which holds the home button in place when it is reattached to the plastic chassis. This piece of metal MUST be transfered if it's not on the new glass/digitizer assembly. If this step is omitted, the home button will not seat properly and will probably just fall out. The worst part is you can't really go back and fix it once you've mated the glass/digitizer to the plastic chassis. As soon as I hit it with heat again, the glass separated from the digitizer and rendered my new screen useless.
If I missed something, I apologize, but its a very important step nonetheless!!
Justin Long - Reply
Excellent. Thx!!
Tom Retson - Reply
My Note 2 can't make calls even though showing full bars, how can I test whether it's a radio/antennae problem or software problem or if something is fried on the motherboard? For more info please see my question I just posted, thanks for the great video!
David - Reply
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 48
All Time: 62,943
