Google Pixel 5 Motherboard Replacement
  1. Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: step 1, image 1 of 3 Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: step 1, image 2 of 3 Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: step 1, image 3 of 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • The SIM card tray is located on the left edge of the phone near the bottom.
    • Press firmly to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Google Pixel 5 Motherboard Replacement, Heat the bottom edge of the screen: step 2, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 5 Motherboard Replacement, Screen removal information: step 3, image 1 of 3 Google Pixel 5 Motherboard Replacement, Screen removal information: step 3, image 2 of 3 Google Pixel 5 Motherboard Replacement, Screen removal information: step 3, image 3 of 3
    • While you're waiting for the adhesive to loosen, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
  4. Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: step 4, image 1 of 3 Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: step 4, image 2 of 3 Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  5. Google Pixel 5 Motherboard Replacement: step 5, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 5, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 5, image 3 of 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and its bezel frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. Google Pixel 5 Motherboard Replacement, Insert an opening pick: step 6, image 1 of 3 Google Pixel 5 Motherboard Replacement, Insert an opening pick: step 6, image 2 of 3 Google Pixel 5 Motherboard Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
  7. Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: step 7, image 1 of 3 Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: step 7, image 2 of 3 Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: step 7, image 3 of 3
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  8. Google Pixel 5 Motherboard Replacement, Heat the left edge of the screen: step 8, image 1 of 1
    • Apply a heated iOpener to the left edge of the screen for one minute.
  9. Google Pixel 5 Motherboard Replacement: step 9, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 9, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 9, image 3 of 3
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
  10. Google Pixel 5 Motherboard Replacement: step 10, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 10, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 10, image 3 of 3
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
  11. Google Pixel 5 Motherboard Replacement: step 11, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 11, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 11, image 3 of 3
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
  12. Google Pixel 5 Motherboard Replacement, Open up the screen: step 12, image 1 of 2 Google Pixel 5 Motherboard Replacement, Open up the screen: step 12, image 2 of 2
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
  13. Google Pixel 5 Motherboard Replacement, Disconnect the screen: step 13, image 1 of 2 Google Pixel 5 Motherboard Replacement, Disconnect the screen: step 13, image 2 of 2
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
  14. Google Pixel 5 Motherboard Replacement: step 14, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 14, image 2 of 2
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
  15. Google Pixel 5 Motherboard Replacement: step 15, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 15, image 2 of 2
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
  16. Google Pixel 5 Motherboard Replacement, Remove the screen: step 16, image 1 of 2 Google Pixel 5 Motherboard Replacement, Remove the screen: step 16, image 2 of 2
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  17. Google Pixel 5 Motherboard Replacement, Remove the graphite tape: step 17, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove the graphite tape: step 17, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove the graphite tape: step 17, image 3 of 3
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
  18. Google Pixel 5 Motherboard Replacement: step 18, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 18, image 2 of 2
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
  19. Google Pixel 5 Motherboard Replacement, Remove the charging plate cover: step 19, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
  20. Google Pixel 5 Motherboard Replacement: step 20, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 20, image 2 of 2
    • Use tweezers to remove the charging plate cover.
  21. Google Pixel 5 Motherboard Replacement: step 21, image 1 of 1
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
  22. Google Pixel 5 Motherboard Replacement, Remove the midframe: step 22, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove the midframe: step 22, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove the midframe: step 22, image 3 of 3
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
    • The spacer at the top of the phone is likely to fall out when you remove the midframe. Remember to save this spacer for reassembly. See pictures in the motherboard replacement guide.
  23. Google Pixel 5 Motherboard Replacement, Disconnect the battery: step 23, image 1 of 2 Google Pixel 5 Motherboard Replacement, Disconnect the battery: step 23, image 2 of 2
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
  24. Google Pixel 5 Motherboard Replacement, Remove the shouldered screw: step 24, image 1 of 1
    • Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
  25. Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: step 25, image 1 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: step 25, image 2 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: step 25, image 3 of 3
    • Use the spudger to disconnect the two rear camera press connectors from the motherboard.
    • Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
  26. Google Pixel 5 Motherboard Replacement, Remove the rear cameras: step 26, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove the rear cameras: step 26, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove the rear cameras: step 26, image 3 of 3
    • Use tweezers to lift up on the rear camera assembly to remove it from its housing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
  27. Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: step 27, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: step 27, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: step 27, image 3 of 3
    • Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers.
    • Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • If the pull tab breaks prematurely, use tweezers to retrieve the remaining length of adhesive and continue pulling.
    • If you are unable to retrieve it, move on to the next step.
  28. Google Pixel 5 Motherboard Replacement: step 28, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 28, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 28, image 3 of 3
    • Use the same process to remove the pull tab located at the bottom left edge of the battery.
    • If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
  29. Google Pixel 5 Motherboard Replacement, Loosen the adhesive: step 29, image 1 of 2 Google Pixel 5 Motherboard Replacement, Loosen the adhesive: step 29, image 2 of 2
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
  30. Google Pixel 5 Motherboard Replacement: step 30, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 30, image 2 of 2
    • Tilt the phone so that the alcohol flows towards the remaining adhesive.
    • Wait one minute for the adhesive to soften, then proceed to the next step.
  31. Google Pixel 5 Motherboard Replacement, Remove the battery: step 31, image 1 of 2 Google Pixel 5 Motherboard Replacement, Remove the battery: step 31, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • Insert an opening pick into the gap long the left side of the battery.
    • Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Avoid scraping the two flex cables under the battery with your opening pick.
    • This may be difficult as the adhesive is strategically located between the cables and the battery tray. A possible solution is to cut a plastic card to fit between the flex cables and battery tray edge.
    • Do not bend the battery.
    • Avoid the earpiece contact pins located near the top left corner of the battery as you pry up with your opening pick.
    • If you cannot pry the battery up, add a few more drops of isopropyl alcohol to the adhesive. A plastic card can also be helpful during this process.
  32. Google Pixel 5 Motherboard Replacement: step 32, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 32, image 2 of 2
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove your old battery.
  33. Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: step 33, image 1 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: step 33, image 2 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: step 33, image 3 of 3
    • Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard.
  34. Google Pixel 5 Motherboard Replacement, Remove the motherboard screws: step 34, image 1 of 1
    • Use a T3 Torx driver to remove the two 2.9 mm screws securing the motherboard to the rear case.
  35. Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: step 35, image 1 of 3 Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: step 35, image 2 of 3 Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: step 35, image 3 of 3
    • Use a spudger to gently fold the flex cable covering the rear case press connector out of the way.
  36. Google Pixel 5 Motherboard Replacement, Disconnect the press connector: step 36, image 1 of 2 Google Pixel 5 Motherboard Replacement, Disconnect the press connector: step 36, image 2 of 2
    • Use the spudger to disconnect the rear case press connector.
  37. Google Pixel 5 Motherboard Replacement, Remove the motherboard: step 37, image 1 of 2 Google Pixel 5 Motherboard Replacement, Remove the motherboard: step 37, image 2 of 2
    • Insert the pointed end of the spudger into the screw holes near the front facing camera.
    • Push the motherboard down towards the bottom of the phone, then lift up to free the top of the motherboard from the rear case.
  38. Google Pixel 5 Motherboard Replacement: step 38, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 38, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 38, image 3 of 3
    • Use your fingers to pull the motherboard up towards the top of the rear case to free the charging port.
    • Do not bend or twist the motherboard.
    • If the motherboard gets caught on the case, use a spudger to go around the edges and loosen it up.
    • Remove the motherboard.
  39. Google Pixel 5 Motherboard Replacement: step 39, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 39, image 2 of 2
    • After removing the motherboard, the top spacer will usually fall out. To replace it, reposition the midframe without screwing it down. Grasp the spacer with the tweezers and compress the interior foam to squeeze it into position. Then screw the midframe into place.
    • Grip the spacer by the body and not by the delicate end tabs.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 other people completed this guide.
Robert Boyd
26,559 Reputation
94 Guides authored
3 Comments
Good day. Please tell me, what is the size of the vibration motor for the pixel 5? I can't find the type of vibro motor anywhere.
Андрей Тарасенко - Reply
Mr. Boyd, where exactly is the proximity sensor inside the Pixel 5 phone?
J. Goodenough - Reply
Any idea on model number for power IC in pixel 5? The technician is saying its Qualcomm PM8996 or PMI 8996 001 Power Management IC. Can somebody please help with my dead pixel 5 please!
Avichal Verma - Reply
Past 24 Hours: 10
Past 7 Days: 88
Past 30 Days: 409
All Time: 14,694
