Google Pixel 9 Front Camera Replacement
  1. Google Pixel 9 Front Camera Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 3 Google Pixel 9 Front Camera Replacement, Prepare your Pixel for disassembly: step 1, image 2 of 3 Google Pixel 9 Front Camera Replacement, Prepare your Pixel for disassembly: step 1, image 3 of 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 Front Camera Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 Front Camera Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 Front Camera Replacement, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 Front Camera Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 Front Camera Replacement, Apply a suction handle: step 3, image 2 of 2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 Front Camera Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 Front Camera Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 Front Camera Replacement, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 Front Camera Replacement, Separate the back glass adhesive: step 5, image 1 of 3 Google Pixel 9 Front Camera Replacement, Separate the back glass adhesive: step 5, image 2 of 3 Google Pixel 9 Front Camera Replacement, Separate the back glass adhesive: step 5, image 3 of 3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Front Camera Replacement: step 6, image 1 of 3 Google Pixel 9 Front Camera Replacement: step 6, image 2 of 3 Google Pixel 9 Front Camera Replacement: step 6, image 3 of 3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 Front Camera Replacement: step 7, image 1 of 3 Google Pixel 9 Front Camera Replacement: step 7, image 2 of 3 Google Pixel 9 Front Camera Replacement: step 7, image 3 of 3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 Front Camera Replacement, Remove the back glass: step 8, image 1 of 1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 Front Camera Replacement, Remove the upper board cover: step 9, image 1 of 1
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 Front Camera Replacement: step 10, image 1 of 2 Google Pixel 9 Front Camera Replacement: step 10, image 2 of 2
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 Front Camera Replacement, Remove the midframe: step 11, image 1 of 1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 Front Camera Replacement, Peel up the flash cable: step 12, image 1 of 2 Google Pixel 9 Front Camera Replacement, Peel up the flash cable: step 12, image 2 of 2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 Front Camera Replacement, Remove the midframe: step 13, image 1 of 2 Google Pixel 9 Front Camera Replacement, Remove the midframe: step 13, image 2 of 2
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 Front Camera Replacement, Disconnect the battery: step 14, image 1 of 2 Google Pixel 9 Front Camera Replacement, Disconnect the battery: step 14, image 2 of 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 Front Camera Replacement, Disconnect the front camera: step 15, image 1 of 2 Google Pixel 9 Front Camera Replacement, Disconnect the front camera: step 15, image 2 of 2
    • Use the tip of a spudger to pry up and disconnect the front camera's press connector.
  16. Google Pixel 9 Front Camera Replacement, Pry up and remove the front camera: step 16, image 1 of 3 Google Pixel 9 Front Camera Replacement, Pry up and remove the front camera: step 16, image 2 of 3 Google Pixel 9 Front Camera Replacement, Pry up and remove the front camera: step 16, image 3 of 3
    • Insert the flat end of a spudger between the top edge of the front camera and the frame.
    • Pivot the spudger down, against the frame to pry the front camera up and out of its recess.
    • Remove the front camera.
  17. Google Pixel 9 Front Camera Replacement, Install new front facing camera adhesive: step 17, image 1 of 3 Google Pixel 9 Front Camera Replacement, Install new front facing camera adhesive: step 17, image 2 of 3 Google Pixel 9 Front Camera Replacement, Install new front facing camera adhesive: step 17, image 3 of 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining liner from the adhesive.
  18. Google Pixel 9 Front Camera Replacement, Adhere the front facing camera: step 18, image 1 of 2 Google Pixel 9 Front Camera Replacement, Adhere the front facing camera: step 18, image 2 of 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable facing the right edge, press the front facing camera into its recess to secure it with the adhesive.
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
156,381 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,818 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 86
All Time: 1,237
