Google Pixel 9 Pro XL Rear Cameras Replacement
Spencer Day
Spencer Day and 2 other contributors
Last updated on October 17, 2024
2 - 3 hours
Moderate
Introduction
Go to step 1
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the rear cameras (wide, ultrawide, and telephoto) in your Google Pixel 9 Pro XL.
The replacement rear cameras come attached in a housing and must be replaced as one assembly—replacing any one camera means replacing all three.
You may need to replace the rear cameras if they're taking distorted or blurry photos, or not taking photos at all.
You'll need replacement autofocus sensor and rear cover adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
iFixit earns commission when you buy through these links.
  1. Google Pixel 9 Pro XL Rear Cameras Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro XL Rear Cameras Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro XL Rear Cameras Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Rear Cameras Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro XL Rear Cameras Replacement, Separate the rear cover adhesive: step 5, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Separate the rear cover adhesive: step 5, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro XL Rear Cameras Replacement: step 6, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 6, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro XL Rear Cameras Replacement: step 7, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 7, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro XL Rear Cameras Replacement, Prop up the rear cover: step 8, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Prop up the rear cover: step 8, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the cable cover: step 9, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the cable cover: step 9, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Google Pixel 9 Pro XL Rear Cameras Replacement: step 10, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement: step 10, image 2 of 2
    • Use tweezers or your fingers to remove the cable cover.
  11. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cover: step 11, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cover: step 11, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cover: step 11, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. Google Pixel 9 Pro XL Rear Cameras Replacement, Peel up the cable cover tape: step 13, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Peel up the cable cover tape: step 13, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Peel up the cable cover tape: step 13, image 3 of 3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the cable cover: step 14, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the cable cover: step 14, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. Google Pixel 9 Pro XL Rear Cameras Replacement: step 15, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement: step 15, image 2 of 2
    • Use tweezers or your fingers to remove the cover.
  16. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the wireless charging assembly: step 16, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the wireless charging assembly: step 16, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. Google Pixel 9 Pro XL Rear Cameras Replacement: step 17, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 17, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 17, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the wireless charging assembly screws: step 18, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the wireless charging assembly screws: step 18, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the wireless charging assembly: step 19, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the wireless charging assembly: step 19, image 2 of 2
    • Remove the wireless charging assembly.
  20. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the battery: step 20, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the battery: step 20, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the battery: step 20, image 3 of 3
    • Use a spudger to pry up and disconnect the battery press connector.
  21. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave cover screw: step 21, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave cover screw: step 21, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.2 mm‑long screw securing the mmWave antenna cover.
  22. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave cover: step 22, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave cover: step 22, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave cover: step 22, image 3 of 3
    • A tight metal clip secures the bottom left corner of the mmWave antenna cover.
    • Insert the point of a spudger under the tab near the bottom left corner of the mmWave antenna cover.
    • Use your spudger to slide the cover to the right while prying up to unclip the cover.
  23. Google Pixel 9 Pro XL Rear Cameras Replacement: step 23, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 23, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 23, image 3 of 3
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  24. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the 5G mmWave antenna: step 24, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the 5G mmWave antenna: step 24, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  25. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the front facing camera: step 25, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the front facing camera: step 25, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  26. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave screw: step 26, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave screw: step 26, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave screw: step 26, image 3 of 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.2 mm‑long screw securing the mmWave antenna.
  27. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave antenna: step 27, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the 5G mmWave antenna: step 27, image 2 of 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
  28. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the interconnect cables: step 28, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the interconnect cables: step 28, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the interconnect cables: step 28, image 3 of 3
    • Use a spudger to pry up and disconnect the three remaining press connectors along the bottom edge of the logic board—two larger press connectors near the center and one smaller one on the bottom right corner.
  29. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the top left cable cover: step 29, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the top left cable cover: step 29, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the metal cover in the top left corner.
  30. Google Pixel 9 Pro XL Rear Cameras Replacement: step 30, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement: step 30, image 2 of 2
  31. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the autofocus cable: step 31, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the autofocus cable: step 31, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the autofocus cable: step 31, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the autofocus sensor press connector from the top left corner of your phone.
    • Gently fold the cable up so you can access the antenna connector beneath it.
  32. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the antenna cable: step 32, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the antenna cable: step 32, image 2 of 2
    • Slide one arm of your angled tweezers under the metal neck of the antenna connector and lift straight up to disconnect it.
    • During reassembly, use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  33. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the logic board screw: step 33, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the logic board screw: step 33, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the logic board screw: step 33, image 3 of 3
    Tool used on this step:
    Standoff Screwdriver for iPhones
    $5.49
    • Use a standoff screwdriver to remove the 4.8 mm‑long standoff screw from the bottom right corner of the logic board.
    • If you don't have a standoff screwdriver, you can use a flathead screwdriver that's as wide as (or slightly wider than) the screw. To avoid stripping, make sure the driver is properly aligned with the screw and apply continuous downward pressure.
  34. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the logic board: step 34, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the logic board: step 34, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the logic board: step 34, image 3 of 3
    • Use a spudger to pry up the top edge of the logic board until you can grip it with your fingers.
    • Grip the right side of the logic board and carefully remove it, being careful that no cables get snagged (one front facing camera cable and four cables along the bottom edge).
    • During reassembly, hold the front facing camera cable out of the way and lower the logic board into place, making sure the four cables along the bottom edge don't get trapped underneath.
  35. Google Pixel 9 Pro XL Rear Cameras Replacement, Reassembly information: step 35, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Reassembly information: step 35, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Reassembly information: step 35, image 3 of 3
    • During reassembly:
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
  36. Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cameras: step 36, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cameras: step 36, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cameras: step 36, image 3 of 3
    • Be very careful not to damage any of the small, surface‑mounted components when disconnecting the cameras in the next two steps.
    • Hold the logic board above your work surface while disconnecting the rear cameras—don't press the board against your work surface, or you may damage fragile components.
    • Use the point of a spudger to pry up and disconnect the autofocus sensor press connector on the top of the logic board, near the left edge.
  37. Google Pixel 9 Pro XL Rear Cameras Replacement: step 37, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 37, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 37, image 3 of 3
    • Carefully flip the logic board over so the bottom is facing up.
    • Use the point of a spudger to pry up and disconnect the three camera press connectors.
  38. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the rear cameras: step 38, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the rear cameras: step 38, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the rear cameras: step 38, image 3 of 3
    • Hold the logic board in one hand, and use your free hand to gently remove the rear cameras.
    • During reassembly, make sure the three camera cables go on the underside of the logic board and the autofocus sensor cable goes on top.
  39. Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the autofocus sensor: step 39, image 1 of 2 Google Pixel 9 Pro XL Rear Cameras Replacement, Remove the autofocus sensor: step 39, image 2 of 2
    • Check if your replacement rear cameras have an autofocus sensor attached. If they don't, follow the remaining steps to remove and transfer the sensor from your old cameras.
    • Apply a heated iOpener to the top of the rear cameras to heat the adhesive securing the autofocus sensor.
    • Alternatively, you can lightly heat the sensor with a hair dryer—be careful not to overheat the sensor, as the plastic can warp.
  40. Google Pixel 9 Pro XL Rear Cameras Replacement: step 40, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 40, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 40, image 3 of 3
    • Gently slide the flat end of a spudger under the bottom right corner of the autofocus sensor (near the cable) to begin separating the adhesive.
    • Continue sliding the spudger under the perimeter of the sensor to separate the remaining adhesive.
  41. Google Pixel 9 Pro XL Rear Cameras Replacement: step 41, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 41, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 41, image 3 of 3
    • Use your fingers to remove the autofocus sensor.
    • Remove any adhesive on the underside of the sensor with a pair of tweezers.
  42. Google Pixel 9 Pro XL Rear Cameras Replacement, Apply new autofocus sensor adhesive: step 42, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Apply new autofocus sensor adhesive: step 42, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Apply new autofocus sensor adhesive: step 42, image 3 of 3
    • Remove the larger, clear plastic liner from your replacement autofocus sensor adhesive.
    • Carefully apply the adhesive to the bottom of the sensor and press down firmly with a spudger to secure it.
    • Peel up the remaining blue liner.
  43. Google Pixel 9 Pro XL Rear Cameras Replacement: step 43, image 1 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 43, image 2 of 3 Google Pixel 9 Pro XL Rear Cameras Replacement: step 43, image 3 of 3
    • Be very careful not to touch the camera lenses during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • If your replacement rear cameras have protective caps or liners, remove them.
    • Before applying the autofocus sensor to your replacement rear cameras, hold the sensor over your replacement cameras and find its proper orientation.
    • There are cutouts on the left edge of the middle camera that line up with the short protrusions on the right edge of the sensor.
    • Carefully lay the sensor over the rear camera and use your fingers to press it into place, securing it with the adhesive.
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
94,599 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,418 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 115
All Time: 851
