HP 15-bs051od Fan Replacement
  1. HP 15-bs051od Fan Replacement, Fan: step 1, image 1 of 1
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
  2. HP 15-bs051od Fan Replacement: step 2, image 1 of 2 HP 15-bs051od Fan Replacement: step 2, image 2 of 2
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
  3. HP 15-bs051od Fan Replacement: step 3, image 1 of 1
    • Disconnect the fan cable and remove the fan.
  4. HP 15-bs051od Fan Replacement: step 4, image 1 of 3 HP 15-bs051od Fan Replacement: step 4, image 2 of 3 HP 15-bs051od Fan Replacement: step 4, image 3 of 3
    • Remove the four 4 mm Phillips screws on the heatsink.
    • Remove the heatsink by carefully lifting it up.
Jessica Walia
589 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 181
