HP 15-bs051od Motherboard Replacement
Introduction
Go to step 1This is a guide for replacing the motherboard for the HP 15-bs051od. Possible reasons to replace the motherboard include the computer produces an increase in Windows errors or the Blue Screen of Death when you turn on the power.
Note: Our model does not include a battery. Before performing any repair ensure the battery has been removed and the computer is not connected to a power source. It is also important to ground yourself by touching metal to discharge excess electricity before beginning the repair.
Start with the laptop face down.
Remove the eight 6 mm Phillips head screws securing the lower case.
Use the opening tool to pry the lower case away from the body of the laptop.
Remove the lower case.
Remove the four (4 mm) Phillips screws on the heatsink.
Remove the exhaust by carefully lifting it up.
Remove the single (4 mm) Phillips screw on the Wi-Fi card.
Slide the Wi-Fi card out of its port.
