HP 15-bs051od RAM Replacement
  1. HP 15-bs051od RAM Replacement, RAM: step 1, image 1 of 1
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
  2. HP 15-bs051od RAM Replacement: step 2, image 1 of 2 HP 15-bs051od RAM Replacement: step 2, image 2 of 2
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
  3. HP 15-bs051od RAM Replacement: step 3, image 1 of 3 HP 15-bs051od RAM Replacement: step 3, image 2 of 3 HP 15-bs051od RAM Replacement: step 3, image 3 of 3
    • Pull the RAM-retaining arms away from the RAM chip.
    • The RAM chip should slightly "pop" up from it's socket.
  4. HP 15-bs051od RAM Replacement: step 4, image 1 of 2 HP 15-bs051od RAM Replacement: step 4, image 2 of 2
    • Pull the RAM chip out of its socket.
    • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
    • Repeat this process for the second RAM chip.
Jessica Walia
589 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 340
