HP 550 Notebook LCD Display Replacement
  1. HP 550 Notebook LCD Display Replacement, LCD display: step 1, image 1 of 1
    • Remove the battery
  2. HP 550 Notebook LCD Display Replacement: step 2, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 2, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 2, image 3 of 3
    • Remove the 8 pads and the underlying screws
  3. HP 550 Notebook LCD Display Replacement: step 3, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 3, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 3, image 3 of 3
    • Use a thin tool to separate the lcd frame
    • Unhook the cover on the 2 hinges on the upper side
  4. HP 550 Notebook LCD Display Replacement: step 4, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 4, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 4, image 3 of 3
    • Remove the LCD cover with delicacy, paying attention to the wires and removing any adhesive if present.
    • Remove 4 lcd fixing screws on one side and 4 screws on the other
    • Force the back cover slightly to access the last screw on both sides
  5. HP 550 Notebook LCD Display Replacement: step 5, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 5, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 5, image 3 of 3
    • Disconnect the lcd panel connector
    • Gently lay the LCD panel on the keyboard.
    • Disconnect video display connector.
  6. HP 550 Notebook LCD Display Replacement: step 6, image 1 of 1
    • Remove the LCD panel and replace with the new one
To reassemble the device, follow these instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,110 Reputation
39 Guides authored
2 Guide Comments
what are those two things on top labeled 1 and 2 in the last picture?
Vladut Prcsina - Reply
Non ho capito la domanda. Grazie
Smilzo -
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 39
All Time: 2,717
