HP Envy x360 m6-w103dx Keyboard Replacement
Steven Ngo
Steven Ngo and 7 other contributors
Last updated on August 16, 2022
5 minutes
Easy
Introduction
Go to step 1
This replacement guide is for the keyboard of the HP Envy x360 m6-w103dx. All you need to complete this guide is a plastic opening tool, a #0 Phillips screwdriver, and an anti-static wrist strap.
Wear the anti-static wrist strap and attach it to a metal surface to avoid damaging sensitive electrical components. Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the keyboard is not dangerous and doesn’t require any special technical skills.
Tools
Show more…
  1. HP Envy x360 m6-w103dx Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP Envy x360 m6-w103dx Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Keyboard Replacement: step 2, image 1 of 2 HP Envy x360 m6-w103dx Keyboard Replacement: step 2, image 2 of 2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Keyboard Replacement: step 3, image 1 of 3 HP Envy x360 m6-w103dx Keyboard Replacement: step 3, image 2 of 3 HP Envy x360 m6-w103dx Keyboard Replacement: step 3, image 3 of 3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Keyboard Replacement: step 4, image 1 of 3 HP Envy x360 m6-w103dx Keyboard Replacement: step 4, image 2 of 3 HP Envy x360 m6-w103dx Keyboard Replacement: step 4, image 3 of 3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
Steven Ngo
963 Reputation
7 Guides authored
Cal Poly, Team S12-G2, Regan Fall 2019 Member of Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
4 Members
23 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 38
Past 30 Days: 111
All Time: 4,486
