HP Omni 10 Speaker Replacement
Introduction
Go to step 1Using a spudger and a 00 Phillips head screwdriver, this guide will show how to remove a pair of speakers from an HP Omni 10 tablet in roughly 5 to 7 minutes.
Push the black plastic security flaps into an upward position.
Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
Lift the tab on the strip up and pull it across the battery.
Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
