You're viewing a previously published version of this guide.  View latest version
Older Newer
HP ProBook 4540s Optical Drive Replacement
Amber Schindler
Amber Schindler and 2 other contributors
Last updated on December 22, 2016
5 minutes
Easy
Introduction
Go to step 1
This guide will help you replace the optical drive, otherwise known as the CD drive. Be sure that no disks are within the drive before replacing the drive.
Tools
  1. HP ProBook 4540s Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: step 2, image 1 of 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: step 3, image 1 of 2 HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: step 3, image 2 of 2
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
  4. HP ProBook 4540s Optical Drive Replacement: step 4, image 1 of 2 HP ProBook 4540s Optical Drive Replacement: step 4, image 2 of 2
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
Amber Schindler
1,042 Reputation
6 Guides authored
UW Tacoma, Team 1-5, Rose Fall 2016 Member of UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 2,472
