How can I mend holes or tears on my backpack?
Introduction
Go to step 1Your backpack has a hole, a tear, or a worn spot? No problem! You can easily repair or cover these small damages with a patch.
In this guide, we’ll show you step by step how to do it yourself. Let’s get started!
Safety Instructions and Disclaimer
Please review deuter’s safety instructions and disclaimer before using this repair guide. The guides on iFixit are for informational purposes only, and using them is at your own risk. Be sure to follow all applicable safety precautions carefully, and seek professional advice if in doubt. deuter accepts no liability for any damage, loss, or injury resulting from the use of the described repair methods.
Parts
Tools
Show more…
Measure the size of the hole or tear: Measure the length and width of the hole or tear. Make sure to note down the dimensions.
Create a template for the patch: Two templates will be made: one for the inner patch and one for the outer patch.
Determine patch size: The patch can be cut in any shape. It's important that the outer patch is at least 1 cm larger on all sides than the measurements of the hole or tear. The inner patch should be at least 1 cm larger on all sides than the measurements of the outer patch.
Transfer the finished template onto the patch fabric (e.g., using a chalk marker). Do not place the template directly against the fabric edge; instead, leave some space around it. Do not cut the fabric yet! (see Step 3)
Roughly cut out the drawn patch shapes. The fabric piece shown here is cut into a rectangle.
Cut the double-sided fabric adhesive to approximately the same size and shape as the fabric piece, ensuring that both patches are fully covered. (The cutting of the adhesive is not shown here; see Step 4.)
Ironing Step 1: Place the double-sided fabric adhesive with the film side facing the left side of the fabric and iron it on. Follow the manufacturer’s instructions for applying the adhesive. Let it cool.
The double-sided fabric adhesive typically has one side coated with silicone paper (Ironing Step 2) and one film side that is not coated with silicone paper (Ironing Step 1).
Special thanks to these translators:
100%
deuter Rucksäcke is helping us fix the world! Want to contribute?
Start translating ›
