How to Fix a Stuck Button in Sharp Calculator
  1. How to Fix a Stuck Button in Sharp Calculator, Button Keys: step 1, image 1 of 1
    • Turn the power off by pressing a button named 2NDF located in the top-left corner.
    • Press the button named ON/C in the top-right corner.
  2. How to Fix a Stuck Button in Sharp Calculator: step 2, image 1 of 2 How to Fix a Stuck Button in Sharp Calculator: step 2, image 2 of 2
    • Flip the calculator over so that the back panel is facing upwards.
    • Remove two 5mm Phillips #0 screws from the battery cover by turning the screwdriver in a counter-clockwise direction.
    • Remove the remaining four 5mm Phillips #0 screws from the back panel cover.
  3. How to Fix a Stuck Button in Sharp Calculator: step 3, image 1 of 1
    • Remove the battery cover.
    • Insert a spudger into the slot located in the top-right corner and pry the battery out.
  4. How to Fix a Stuck Button in Sharp Calculator: step 4, image 1 of 1
    • Remove the front panel by sticking an opening tool into a small gap between front and back panel.
    • Push the tool down with force and pry open the right side carefully.
    • Detach the front panel from the back panel by lifting the front board.
    • Separate the front and back panel slowly to avoid damaging the LCD ribbon.
  5. How to Fix a Stuck Button in Sharp Calculator: step 5, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws from the motherboard.
  6. How to Fix a Stuck Button in Sharp Calculator: step 6, image 1 of 2 How to Fix a Stuck Button in Sharp Calculator: step 6, image 2 of 2
    • Lift the motherboard by holding both sides and placing it on the top panel.
    • Lift the grey padding upwards by holding any corner and place it on top of the motherboard.
    • Press the grey padding and put pressure downward to avoid sticking from physical buttons.
  7. How to Fix a Stuck Button in Sharp Calculator: step 7, image 1 of 2 How to Fix a Stuck Button in Sharp Calculator: step 7, image 2 of 2
    • Use a spudger to flip, remove, and adjust the position of buttons.
    • Ensure the placement of buttons is correct. Use STEP 1 Image as a reference to the location of buttons.
2 other people completed this guide.
Attached Documents
Micah Bustamante
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 61
All Time: 5,057
