Introduction
Bring life back to your iPhone 6 with a new replacement battery—it’s easy and will have a big impact! If your battery is swollen, take appropriate precautions.
This guide instructs you to remove the front panel assembly; this is intended to prevent damage to the display cables. If you feel comfortable supporting the display carefully while peeling the battery out of the iPhone, you can skip the display removal and go directly to the battery removal steps.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
You can also use this guide to replace the following parts:
Video Overview
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Peel back the first battery adhesive tab from the bottom right edge of the battery.
Slowly pull the adhesive tab away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
If the strip breaks, carefully try to retrieve it with your tweezers (without damaging the battery) and continue pulling. If the strip breaks off underneath the battery and can't be retrieved, continue with the steps below.
If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too hot to touch comfortably.
Then, use a plastic opening tool to gently lift the battery.
A stronger alternative to floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
Remove the battery from the iPhone.
Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
Adhere the battery, disconnect it, and continue reassembling your device.
3282 other people completed this guide.
408 Comments
Is it absolutely necessary to do step 11-15
Or is it possible to lean the front panel up while still connected and only removing the battery screws and the battery
I strongly recommend following ALL of the steps as shown. The cables are extremely fragile and can tear easily. It will only add about 5 minutes or so to the project, but could save hours and dollars. Also, take your time removing the battery adhesive strips. If they break off underneath the battery, they are a bear to get out.
I definitely skipped ahead and left these attached. I just held the screen up and only laid it down to apply the adhesive to the new battery.
leon -
I stuck the screen on to an iPhone box (just like in the photo) and did not have to remove the display cables.
BUT, you need to be very careful -- especially if the white strips break on you. If you need to use the plastic card and/or heat to remove the battery, I recommend disconnecting the display.
Carlos -
