How to Wash a Waterproof Jacket
  1. How to Wash a Waterproof Jacket, Wipe away dirt and debris: step 1, image 1 of 2 How to Wash a Waterproof Jacket, Wipe away dirt and debris: step 1, image 2 of 2
    • Look over your jacket and wipe away dirt and debris.
    • For stubborn stains, spot clean using a mild soap or rubbing alcohol. See Spot Cleaning Technical Gear for more details.
  2. How to Wash a Waterproof Jacket, Prepare your jacket: step 2, image 1 of 3 How to Wash a Waterproof Jacket, Prepare your jacket: step 2, image 2 of 3 How to Wash a Waterproof Jacket, Prepare your jacket: step 2, image 3 of 3
    • Zip up the main zipper.
    • Leave pockets unzipped so they can be cleaned inside.
    • Empty all pockets. Check for trash, treasures, or forgotten tissues.
    • Loosen drawstrings and drawcords.
    • Fasten any hook-and-loop closures in their most relaxed position to avoid snagging.
  3. How to Wash a Waterproof Jacket, Load the washing machine: step 3, image 1 of 1
    • Place your jacket in the washing machine.
    • Add 1-3 jackets at a time. Avoid overfilling the drum—technical garments need room to move freely in the wash.
    • Ideally, use a front-loading washer.
    • Top-loaders usually have agitators, a rotating spindle that creates friction to clean your gear. Jackets can get caught in that spindle, leading to tangles, tears, or scratches.
    • If you don’t have a washing machine, hand-washing is a great alternative. You'll still need a dryer or iron to heat-set afterward!
  4. How to Wash a Waterproof Jacket, Add detergent: step 4, image 1 of 1
    • Add technical gear soap or gentle biodegradable laundry detergent to the washing machine.
    • Patagonia recommends Storm Wash, which is specially formulated for technical outerwear and equipment.
    • For standard detergent, choose one that's liquid, biodegradable, and free of dyes. Look for labels like "organic" or "sensitive skin."
    • Avoid detergent containing fabric softeners, stain removers, perfumes, whiteners, or bleach.
  5. How to Wash a Waterproof Jacket, Set the washing machine: step 5, image 1 of 2 How to Wash a Waterproof Jacket, Set the washing machine: step 5, image 2 of 2
    • Set the load size to small or medium, depending on the number of garments you're washing.
    • Set the water temperature to cold or warm.
    • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
    • Set the spin cycle to low.
    • Start the washing machine.
  6. How to Wash a Waterproof Jacket, Tumble Dry: step 6, image 1 of 3 How to Wash a Waterproof Jacket, Tumble Dry: step 6, image 2 of 3 How to Wash a Waterproof Jacket, Tumble Dry: step 6, image 3 of 3
    • Hang the jacket up to drip dry first to remove excess water, then tumble dry on low heat for at least 30 minutes or until the jacket is fully dry.
    • Don't skip the dryer! Heat activates the durable water resistant (DWR) coating.
    • If you don’t have a dryer, you can use an iron to reactivate the DWR. Carefully follow the steps in How to Iron a Waterproof Jacket.
    • Your jacket is clean, dry, and ready for whatever the weather throws your way!
    • Get back out there!
Finish Line
8 other people completed this guide.
Clara Redwood
2,559 Reputation
18 Guides authored
Patagonia Member of Patagonia
Community
15 Members
137 Guides authored
7 Guide Comments
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
Albert Daniel - Reply
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Rachel - Reply
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
Sarah Geers - Reply
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
choffman - Reply
They absolutely will replace it or give you store credit.
Nathan Keirn -
Past 24 Hours: 14
Past 7 Days: 88
Past 30 Days: 407
All Time: 58,520
