Huawei Ascend G610 Digitizer Replacement
  1. Huawei Ascend G610 Digitizer Replacement, Digitizer: step 1, image 1 of 1
    • This is a touchscreen with shattered glass.
  2. Huawei Ascend G610 Digitizer Replacement: step 2, image 1 of 1
    • Remove the outer cover.
  3. Huawei Ascend G610 Digitizer Replacement: step 3, image 1 of 1
    • Remove the battery.
  4. Huawei Ascend G610 Digitizer Replacement: step 4, image 1 of 1
    • With the help of a heat source and a cross-head screwdriver, remove the 9 screws along the sides of the phone . One screw is covered by an adhesive label.
    • Remove the shortest screw that secures the center of the body, located next to the SIM card.
  5. Huawei Ascend G610 Digitizer Replacement: step 5, image 1 of 2 Huawei Ascend G610 Digitizer Replacement: step 5, image 2 of 2
    • With the help of thin tool, unhinge the joints between the outer cover and the internal frame of the display.
  6. Huawei Ascend G610 Digitizer Replacement: step 6, image 1 of 2 Huawei Ascend G610 Digitizer Replacement: step 6, image 2 of 2
    • Unplug the touchscreen connector.
  7. Huawei Ascend G610 Digitizer Replacement: step 7, image 1 of 3 Huawei Ascend G610 Digitizer Replacement: step 7, image 2 of 3 Huawei Ascend G610 Digitizer Replacement: step 7, image 3 of 3
    • If the glass is broken, apply Scotch tape to avoid further damage.
    • Use a heat source to heat the edge of the glass.
    • With a thin tool
    • Insert translation here
  8. Huawei Ascend G610 Digitizer Replacement: step 8, image 1 of 2 Huawei Ascend G610 Digitizer Replacement: step 8, image 2 of 2
    • Once the touch screen has been removed, proceed with the cleaning of the remaining double-sided adhesive tape
    • Apply the new double-sided adhesive and the new touch screen
    • To reassemble the device follow all the steps in reverse order
To reassemble the device, follow these instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,447 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 912
