You're viewing a previously published version of this guide.  View latest version
Older Newer
Huawei Honor 6x Back Cover Replacement
Hudson Brooks
Hudson Brooks and 4 other contributors
Last updated on September 4, 2021
10 - 20 minutes
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
This guide will be detailing how to separate the screen and back panel in your Huawei Honor 6x. This the first step in most replacement guides for this device.
Tools
Show more…
  1. Huawei Honor 6x Back Cover Replacement, SIM Card: step 1, image 1 of 1
    • Turn off the device.
  2. Huawei Honor 6x Back Cover Replacement: step 2, image 1 of 2 Huawei Honor 6x Back Cover Replacement: step 2, image 2 of 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Back Cover Replacement: step 3, image 1 of 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Back Cover Replacement: step 4, image 1 of 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Back Cover Replacement, Back Cover: step 5, image 1 of 2 Huawei Honor 6x Back Cover Replacement, Back Cover: step 5, image 2 of 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Back Cover Replacement: step 6, image 1 of 3 Huawei Honor 6x Back Cover Replacement: step 6, image 2 of 3 Huawei Honor 6x Back Cover Replacement: step 6, image 3 of 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Back Cover Replacement: step 7, image 1 of 2 Huawei Honor 6x Back Cover Replacement: step 7, image 2 of 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Back Cover Replacement: step 8, image 1 of 3 Huawei Honor 6x Back Cover Replacement: step 8, image 2 of 3 Huawei Honor 6x Back Cover Replacement: step 8, image 3 of 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Back Cover Replacement: step 9, image 1 of 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
Hudson Brooks
495 Reputation
2 Guides authored
Cal Poly, Team S13-G5, White Fall 2018 Member of Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 18
All Time: 101
