Huawei Mate 8 LCD Screen Replacement
Video Instructions
9 other people completed this guide.
Witrigs
70,169 Reputation
377 Guides authored
10 Comments
Can I just send my phone to you to fix? I don't want to mess anything up. If yes, how much will you charge?
Jordiana Charles - Reply
I'm sorry, we only provide video for repair. Just follow the steps shown in the video and be careful, difficult doesn't mean it can not be done. take it easy :)
Witrigs -
Okay, well thank you.
Pls were to get the LCD screen for replacement of Mate 8
Musa Abdullahi - Reply
In Abuja Nigeria
Says they don't fix phones, that's bull as they have said in many videos they have an iPhone repair shop, that takes and repairs all iPhones and ipads. Why not androids too? You clearly know how but won't for whatever reason which is sad. Also gave no where to get parts for the repairs ourselves, sad place here.
Ron Brown - Reply
Adakah tempat penjual LCD+touchscreen diBogor Indonesia?Kalau boleh tau lokasi dimana?Terima kasih
Jayanti - Reply
Dimanakah bisa saya dapatkan LCD+touchscreen HP Huawei mate 8 di Bogor Indonesia?
Jayanti - Reply
This Video is irritating. It starts opening the back cover and removing the LCD from the frame. It goes on, as if you would have needed to remove components from the frame backside as well. However, if you only want to replace the LCD (broken glass/LCD/touch) then you just need to heat it up and remove the screen with a plectrum or something similar (which may finally destroy the LCD). Removal of circuit boards or battery is not needed! Maybe remove the selfie camera before, to avoid damage. Pushing the spudger through the camera hole will not work with a broken glass btw. The LCD cable can be pulled carefully through the slot at the bottom of the battery. Transfer the ear speaker cover to the new screen!
If you ordered a display unit INCLUDING frame then better look up the “Display Replacement“ howto of D. Schnabelrauch. Both ways lead to difficulties - either you have the complicated battery removal or the LCD will probably break and can not be but onto shelf for lateron emergency data recovery operations.
Johannes - Reply
The video is a bit irritating: it starts opening the back cover and removing the LCD from the frame. It goes on, as if it was necessary to remove components from the frame backside as well. However, if you only want to replace the LCD (broken glass/LCD/touch) then you just need to heat the LCD up and remove it with the plectrum or similar (which may finally destroy the LCD). Removal of circuit boards or battery is not needed! Maybe remove the selfie camera before, to avoid damage. Pushing the spudger through the camera hole against the glass will not work if it is broken btw. The LCD cable can be pulled carefully through the slot at the bottom of the battery. Don’t forget to reuse the old ear speaker cover!
If you ordered a display unit INCLUDING frame then better look up the “Display Replacement“ howto of D. Schnabelrauch… both ways lead to difficulties - either you have the complicated battery removal or the LCD will probably break and can not be put onto shelf for later emergency data recovery operations.
Johannes - Reply
Past 24 Hours: 8
Past 7 Days: 72
Past 30 Days: 166
All Time: 23,155
