Introduction
This guide shows you how to replace the broken display in your Huawei P8 Lite.
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
Tool used on this step:Plastic Cards$2.99
Heat up the top, bottom and both sides of the display with an iOpener to soften the adhesive.
To reassemble your device, follow these instructions in reverse order. Make sure to test the new display and remove any old residue from the adhesive.
31 other people completed this guide.
