Huawei Watch GT Battery Replacement
  1. Huawei Watch GT Battery Replacement, How to open the Huawei Watch GT: step 1, image 1 of 1
    • Before you begin, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Huawei Watch GT Battery Replacement: step 2, image 1 of 1
    • Remove the four Torx T3 screws (3.65 mm length).
  3. Huawei Watch GT Battery Replacement: step 3, image 1 of 3 Huawei Watch GT Battery Replacement: step 3, image 2 of 3 Huawei Watch GT Battery Replacement: step 3, image 3 of 3
    • Insert an opening pick into the notch at the top edge of the back cover.
    • Do not insert the opening pick deeper than 1 cm (1/3rd of an inch) to avoid damage to other components.
    • Use the opening pick to pry up the back cover of the Huawei Watch GT.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  4. Huawei Watch GT Battery Replacement: step 4, image 1 of 2 Huawei Watch GT Battery Replacement: step 4, image 2 of 2
    • Carefully fold the back cover assembly to the side of the two watch crowns.
  5. Huawei Watch GT Battery Replacement, Battery: step 5, image 1 of 1
    • It's not required to separate the front and back cover assemblies of the Huawei Watch GT to remove the battery. However, it's an easy procedure and we recommend doing so to make the battery removal easier. In case you feel confident without separating the parts, you can jump to step 8.
    • Remove the Phillips #00 screw (2.9 mm length).
  6. Huawei Watch GT Battery Replacement: step 6, image 1 of 2 Huawei Watch GT Battery Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the metal shield which covers the flex connector of the distribution cable.
  7. Huawei Watch GT Battery Replacement: step 7, image 1 of 2 Huawei Watch GT Battery Replacement: step 7, image 2 of 2
    • Use a spudger to pry up and disconnect the distribution cable connector.
  8. Huawei Watch GT Battery Replacement: step 8, image 1 of 1
    • Remove the two Phillips #00 screws (2.6 mm length).
  9. Huawei Watch GT Battery Replacement: step 9, image 1 of 2 Huawei Watch GT Battery Replacement: step 9, image 2 of 2
    • Use a pair of tweezers to remove the metal shield which secures the battery connector.
  10. Huawei Watch GT Battery Replacement: step 10, image 1 of 2 Huawei Watch GT Battery Replacement: step 10, image 2 of 2
    • Use a spudger to pry up and disconnect the battery flex connector.
  11. Huawei Watch GT Battery Replacement: step 11, image 1 of 1
    • Apply a heated iOpener to the rear side of the back cover assembly to loosen the adhesive which is holding the battery in place. Apply the iOpener for at least two minutes.
  12. Huawei Watch GT Battery Replacement: step 12, image 1 of 3 Huawei Watch GT Battery Replacement: step 12, image 2 of 3 Huawei Watch GT Battery Replacement: step 12, image 3 of 3
    • Insert a spudger between the top edge of the battery and the back cover.
    • Use the spudger to pry the battery out of its recess.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
To reassemble your Huawei Watch GT follow these instructions in reverse.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
15 other people completed this guide.
Dominik Schnabelrauch
252,363 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,273 Guides authored
5 Guide Comments
Vielen Dank für die super ausführliche und sehr gut verständliche Anleitung. Habe keine 30 Minuten als absoluter Anfänger gebraucht, um den Akku der smartwatch zu tauschen 👍
killer-kitty - Reply Share
I have a GT2 46mm . It looks a little different inside . Have you maybe instructions for these too?
εφη αραμπατζη - Reply Share
Sehr schön, dass der Akku hier so einfach tauschen lässt. Meiner hält noch locker zwei Wochen durch, obwohl die Uhr schon einige Jahre auf dem Buckel hat.
Alexander Ehne - Reply Share
Hi there. I would like to replace my battery at my gt3 42". Is the gt2 battery compatible? If not, where can i find one?
Thank you in advance
SEVASTH GIANNAKH - Reply Share
Super Anleitung ich werde einen neuen Akku bestellen und dann ran an den Speck Quatsch an den Akku ;-)
Dietmar Derbort - Reply Share
Past 24 Hours: 10
Past 7 Days: 173
Past 30 Days: 637
All Time: 31,030
