Huawei ascend G700 Touchscreen Display Replacement
  1. Huawei ascend G700 Touchscreen Display Replacement, Touchscreen Display: step 1, image 1 of 2 Huawei ascend G700 Touchscreen Display Replacement, Touchscreen Display: step 1, image 2 of 2
    • Remove the back cover and battery
  2. Huawei ascend G700 Touchscreen Display Replacement: step 2, image 1 of 1
    • Remove the indicated screws
  3. Huawei ascend G700 Touchscreen Display Replacement: step 3, image 1 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 3, image 2 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 3, image 3 of 3
    • unhook Central frame using a thin tool behind joints along the entire perimeter of the phone
  4. Huawei ascend G700 Touchscreen Display Replacement: step 4, image 1 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 4, image 2 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 4, image 3 of 3
    • Unplug the touchscreen connector.
    • Unplug the motherboard connector.
    • Unplug the side volume key connector.
  5. Huawei ascend G700 Touchscreen Display Replacement: step 5, image 1 of 2 Huawei ascend G700 Touchscreen Display Replacement: step 5, image 2 of 2
    • Unplug the display connector.
    • Unplug the camera connector.
  6. Huawei ascend G700 Touchscreen Display Replacement: step 6, image 1 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 6, image 2 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 6, image 3 of 3
    • Unplug the motherboard.
  7. Huawei ascend G700 Touchscreen Display Replacement: step 7, image 1 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 7, image 2 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 7, image 3 of 3
    • Remove the camera with a heat source because it's glued to the bottom.
    • Remove the motherboard from the main body of the phone.
    • Remove the power button using a heat source.
    • Remove the volume key using a heat source.
  8. Huawei ascend G700 Touchscreen Display Replacement: step 8, image 1 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 8, image 2 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 8, image 3 of 3
    • Remove the speaker cover.
    • Using a heat source, delicately remove the daughterboard.
  9. Huawei ascend G700 Touchscreen Display Replacement: step 9, image 1 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 9, image 2 of 3 Huawei ascend G700 Touchscreen Display Replacement: step 9, image 3 of 3
    • Remove the speaker using a heat source.
    • Remove the technical adhesive strips using a heat source.
To reassemble the device, follow this instructions in reverse order.
5 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,161 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 19
All Time: 2,120
