You're viewing a previously published version of this guide.  View latest version
Older Newer
JBL Charge 2 Plus Passive Radiators Replacement
John Reynolds
John Reynolds and one other contributor
Last updated on February 16, 2018
30 - 35 minutes
Moderate
Better Introduction
Tools
  1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: step 1, image 1 of 2 JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: step 1, image 2 of 2
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 1 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 2 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 3 of 3
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Passive Radiators Replacement: step 3, image 1 of 2 JBL Charge 2 Plus Passive Radiators Replacement: step 3, image 2 of 2
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Passive Radiators Replacement: step 4, image 1 of 1
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 1 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 2 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 3 of 3
    • Repeat Step 2, 3 and 4 for the other passive radiator.
John Reynolds
3,246 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2015 Member of UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 17,857
