Introduction
This repair is surprisingly easy: you need a guitar pick, your fingernails, and some wedge to pull the battery out of its backing glue. It might be dangerous because the battery is flexible and could burn or explode if punctured, but in practice it seems safe enough.
This is similar to the kobo glo ereader Screen Replacement but easier. See this thread for a detailed discussion.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
1. flip it backwards so it is face down on your desk
2. use a pick or your fingernails to pry the back open
3. when done, you should see the battery (in grey) and the main board (in green)
The connector is white at the end of red/black cables
It can be disconnected with tweezer or (more easily) just with your fingers
You can start prying out the old battery by picking at a corner if there's a flat piece of plastic without any battery stuff under it, as in the picture.
When the battery is about this removed, you may be able to just pull it out with your fingers.
The battery is glued to the back of the front panel.
Also: you might want to keep it around in case your repair fails and you need to put it back in.
Place the new battery down in the place of the old one.
Plug in the power cable, I found that the easiest is to just push it in with my fingers. Make sure it is well connected and flat down on the board.
7 other people completed this guide.
7 Comments
Take lots of time to very gently pry battery out. Carefully, so as not to rupture the battery skin, insert a steel ruler 1mm thick 3cm wide under the short side. Push gently and wiggle left and right. When it doesn't slide further without force, leave it somewhere safe (fire) at body temperature (soften glue), with the ruler in place. Do not overheat beyond body temp. Wait 15 minutes and repeat pushing and waiting. The battery will eventually let go with virtually no bending at all. Certainly no deformation as shown in the pic here.
Thanks, that's valuable advice! I've amended the battery step to point to your comment, in case people want to do the right thing...
anarcat -
Thank you so much for this guide! I used it to replace the battery in my Kobo Clara HD. The internals are in a slightly different orientation but I can confirm that it uses the same battery as the Glo and that the replacement linked in this guide will work. The double sided tape you suggested works great too. Thanks again!
