Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
Lift battery up here
Step 2 Midframe
Careful: steps 2-3 are sourced from a guide that's marked as in-progress.
Remove 11 Philips screws.
Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Tool used on this step:Halberd Spudger$2.99
Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
Step 5 Motherboard Removal
Careful: step 5 is sourced from a guide that's marked as in-progress.
Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
The vibrator motor is held in with strong adhesive.
Insert the tip of a metal spudger on the right side of the vibrator motor and pry it upwards.
