MFC-J4410DW Upper Cover Removal
  1. MFC-J4410DW Upper Cover Removal, Preparation: step 1, image 1 of 3 MFC-J4410DW Upper Cover Removal, Preparation: step 1, image 2 of 3 MFC-J4410DW Upper Cover Removal, Preparation: step 1, image 3 of 3
    • Before beginning disassembly, turn off the printer and unplug the power cord.
    • Open the front access door and remove any cards or cables present. Close the access door.
    • Remove the paper tray.
    • Remove the ink cartridges.
    • You may wish to install the Protective Part to prevent the ink tubes from drying while the cartridges are removed.
    • Open the printer cover using the finger holds on the sides.
    • Unplug and remove any cords present under the cover.
    • Remove the LAN port and EXT port caps (if present).
  2. MFC-J4410DW Upper Cover Removal, Removing the cover support: step 2, image 1 of 3 MFC-J4410DW Upper Cover Removal, Removing the cover support: step 2, image 2 of 3 MFC-J4410DW Upper Cover Removal, Removing the cover support: step 2, image 3 of 3
    • While holding the cover with one hand, pull the hook on the back of the support damper, then remove the damper from the cover.
    • Remove the damper from the support.
    • Turn the support upright and pull it straight out of the printer.
  3. MFC-J4410DW Upper Cover Removal, Removing the harness cover: step 3, image 1 of 2 MFC-J4410DW Upper Cover Removal, Removing the harness cover: step 3, image 2 of 2
    • Use your finger or a spudger to unhook the two tabs on the right side of the harness cover by levering it up.
    • Remove the harness cover. There are two tabs on the left side that you have to wiggle free, and one on the front.
  4. MFC-J4410DW Upper Cover Removal, Removing the grounding screw: step 4, image 1 of 1
    • Remove the 6 mm Phillips #2 screw from the grounding wire of the ADF motor harness.
    • Torque: 0.40±0.10 N•m
    • The Brother service manual lists torques for all screws, but proper torque should not be necessary.
  5. MFC-J4410DW Upper Cover Removal: step 5, image 1 of 1
    • In the proceeding steps, you will disconnect the following cables:
    • CIS flat cable
    • Scanner motor harness
    • ADF motor harness
    • Document detection/document scanning position sensor harness
  6. MFC-J4410DW Upper Cover Removal: step 6, image 1 of 1
    • Pull the CIS flat cable out of its socket.
    • Pull all flat cables directly up out of their sockets, pulling on the cables themselves at the blue tabs.
  7. MFC-J4410DW Upper Cover Removal: step 7, image 1 of 1
    • Pull the scanner motor harness out of its socket.
  8. MFC-J4410DW Upper Cover Removal: step 8, image 1 of 1
    • Pull the ADF motor harness out of its socket.
  9. MFC-J4410DW Upper Cover Removal: step 9, image 1 of 1
    • Pull the document detection/document scanning position sensor harness out of its sockets.
  10. MFC-J4410DW Upper Cover Removal, Opening the scanner harness holder: step 10, image 1 of 2 MFC-J4410DW Upper Cover Removal, Opening the scanner harness holder: step 10, image 2 of 2
    • Insert a spudger between the scanner harness holder and frame to release the tab. There is a second tab on the opposite side.
    • Lift the scanner harness holder out of its frame.
    • Reassembly Note: Before reattaching the harness holder, it is advisable to reattach the cover support (Step 2) to minimize tension on the wiring harnesses.
  11. MFC-J4410DW Upper Cover Removal, Securing the scanner harness holder: step 11, image 1 of 2 MFC-J4410DW Upper Cover Removal, Securing the scanner harness holder: step 11, image 2 of 2
    • Push on the tab to secure the scanner harness holder to the scanner cover.
    • De-route the document detection/document scanning position sensor harness and the ADF motor harness from the scanner harness holder.
    • During reassembly, put a 20mm-thick pad (book, stack of paper) on the scanner glass, close the scanner cover, then route the document detection/document scanning position sensor harness and the ADF motor harness through the harness holder. This will ensure the proper harness tension to allow scanning of thick books.
  12. MFC-J4410DW Upper Cover Removal, Removing the scanner cover: step 12, image 1 of 1
    • Using both hands, pull the scanner cover to the rear while holding it vertically, then lift it off of the printer.
  13. MFC-J4410DW Upper Cover Removal, Removing the upper cover: step 13, image 1 of 2 MFC-J4410DW Upper Cover Removal, Removing the upper cover: step 13, image 2 of 2
    • Remove the six 12 mm Phillips #2 screws securing the upper cover to the printer.
    • Torque: 0.70±0.10 N•m
    • Pull off the upper cover.
    • When reinstalling, ensure that the control panel wiring holder slides into its slot on the upper cover.
  14. MFC-J4410DW Upper Cover Removal, Removing the ink absorber box wiring: step 14, image 1 of 2 MFC-J4410DW Upper Cover Removal, Removing the ink absorber box wiring: step 14, image 2 of 2
    • Remove the ink absorber full sensor from its socket.
    • De-route the wiring from its harness.
  15. MFC-J4410DW Upper Cover Removal, Unhooking the ink absorber: step 15, image 1 of 1
    • Unclip the ink absorber from the harness by pulling it up and to the right.
8 other people completed this guide.
Calion
3,490 Reputation
3 Guides authored
Syler Solutions Member of Syler Solutions
Business
1 Member
12 Guides authored
6 Comments
Muchas gracias me encanta la dedicacion y lo claro que esta hecho el manual.
Patricia Verdera - Reply
Calion,
Quite good instructions. However I needed to get to the power supply, and most of this was very useful, because there are 2 screws supporting the power supply you need to take out with the uper cover removed and the fronf left corner moulding removed. But step 14 and 15 are not necessary, and some of the cable disconnections are not needed.
On step 2 also showing the support damper (removed) with an arrow showing the hook on the back of the support damper would have saved lots of time as I had great difficulty with this step.
Thanks again
Ian
Ian Shannon - Reply
I can see how that would be helpful. Feel free to add it!
Calion -
Very good guide
Donovan Carlson - Reply
Thanks! Glad it was helpful!
Calion -
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 4,263
